Old 07-23-2011, 10:30 AM   #14
Lil Abner
Drives: 2009 3dr LB Manual
Thanks for the info Scott! Pin 6 for the rear intermit is an output, or input? I'll head outside and confirm that.
Last night I spent some time making a circuit with parts I had laying around. I was shocked I had everything. I'm using a 555, 100uF, 0.1uF, 10K-ohm, 500K-ohm variable, a couple diodes, and either a relay or output transistor. It's got a 0.7 second on pulse, and variable off pulse. Works great on the bench, now I'm planning on seeing if it works in the car. I think I have some pins (assuming their the same as the fog light pins). I'll try to post my results. I know people would love a DIY on this.
Removing rear wiper fred812 Cosmetic Modifications (Exterior/Interior) 34 01-27-2013 12:22 AM
Slight mod to rear NickNickNick Cosmetic Modifications (Exterior/Interior) 4 05-11-2006 01:03 AM
