Old 08-02-2011, 07:33 PM   #12
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by Parmas View Post
Dyno is scheduled on 29 August and I hope some good numbers at the wheels.
I am a bit worried how much boost and revs I am going to give her because of the stock head so if any would give a heads up of a limit just post it here...
During the time I found a good deal on a set of D2 racing shocks. They are extremely sensitive on street and I can feel every little bump on the street (not comfortable at all) but at least rock solid on street corners.
Also I am having less wheelspin when giving her full throttle from a stop sign
Here is the update:
Boost as much as your fuelling is good for! I have stock head and head bolts too. 7300 rpm has been just fine. I can vouch that the stock head can withstand past 8000rpm as I accidentally found out twice ( dropped it in 2nd instead of 4th on the dragstrip.. whoops ). I wouldn't set it at 8000rpm though lol. My factory tach won't read past 8000rpm so Im not too sure what it went too. Is It bad when the 1nzfe sounds like an F1 engine? jk.
Set it at 7300 if it still makes power.
I just looked at your picture few posts above... make sure your pipes are bead rolled or the dyno session may get pricey if they have to keep putting back blown off intercooler pipes. May be fine at the boost you're at now........
Ptuning.com
Blown_xa is offline   Reply With Quote
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
