Old 08-04-2011, 07:43 PM   #1
bankrobber
Drives: 2007 Yaris Hatchback
headlight bulb
I put in a new bulb and forgot how it goes in. Should the new bulb have the little cover facing up? I am talking about when you look closely at the bulb you will see a little piece that directs the light. Think I might have put mine in wrong. Seems the light not reflecting the right way.
It was not bad to replace. Pulled off the bumper cover and took headlight assembly out. 20 minute job
bankrobber is offline   Reply With Quote
Old 08-05-2011, 12:06 AM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
They only go in one way. They have tabs on them. How can you manage to put them in and lock them down with the spring clip otherwise?
Old 08-06-2011, 08:06 PM   #3
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
^ +1 ^
OTA'sTOY is offline   Reply With Quote
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
Headlight question bulb sizes.. Darwin84020 DIY / Maintenance / Service 1 12-21-2010 10:00 PM
DIY - A EASY&FAST way to change headlight bulb ALLBLACK DIY / Maintenance / Service 0 09-18-2010 01:40 AM
Headlight bulb which is the best one but legal in australia Pwr_Dori DIY / Maintenance / Service 3 07-27-2010 05:04 PM
Changing Headlight Bulb Tutorial RSboyz DIY / Maintenance / Service 29 03-15-2007 01:35 PM
