Old 12-21-2010, 08:48 PM   #1
Darwin84020
Drives: 2007 Yaris, Hatchback
Exclamation Headlight question bulb sizes..
Hello,
My right headlights' main bulb (big one) stopped working on just normal light when turned on, bright setting both lights work fine.
I have checked fuses, did not see any blown, although did not remove the fuse (not sure how)..
Im getting the light(s) replaced... replacing the H4 light big bulb.
However my question is this - the little bulb, is that an H11 bulb or other spec?? if so think i might just replace that too... to be brighter.. :)
I have a HB 2007 base model.
Darwin
Darwin84020 is offline   Reply With Quote
Old 12-21-2010, 10:00 PM   #2
It is likely that the right bulb's low beam filament is burned out.
The little bulb is a 2825, which is a small wedge base bulb.
Silverstar Ultra 9003/HB2 vs OEM headlight bulb comparison CTScott DIY / Maintenance / Service 54 02-14-2011 08:58 AM
replacement bulb question justinparadise21 Cosmetic Modifications (Exterior/Interior) 2 11-06-2008 01:52 AM
Changing Headlight Bulb Tutorial RSboyz DIY / Maintenance / Service 29 03-15-2007 01:35 PM
Quick headlight question silverRS Cosmetic Modifications (Exterior/Interior) 3 06-21-2006 09:54 AM
