Old 08-16-2011, 12:55 AM   #1
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Correct if you have factory DRLs. If you don't then the tails are the opposite polarity and you have to provide +12V to pin 10 (T1) instead of a ground to 13 (B1).
I do have factory DRLs however I disabled it, does this change anything? At any rate, I'll gather the relays/diodes I need and work on this sometime this week or next.
Can you kindly do one final review of what I'm about to do based on this diagram I created?
Many thanks again Scott
* Headlamp control status after low-light is detected by sensor -> Relays switch pin 13 (tail) and 8 (Low) to GND:
-toy
Old 08-16-2011, 09:27 AM   #2
-toy
Perfect.
Old 08-16-2011, 12:03 PM   #3
toy_toronto
always toyin'
Drives: 2010 5-Dr
Originally Posted by Lil Abner View Post
Is there a sensitivity adjustment for the headlights?
Besides the sensitivity adjustment for rain/moisture detect in the sensor area, I can't find anything in the manual that mentions about sensitivity adjustment for ambient light unfortunately.
How the Rain Tracker Controls Headlamps
Really, really well. The Rain Tracker senses the ambient light level outside the vehicle, and turns
on the headlamps when it is dark, or when it is raining. Most US States require you to have your
headlamps on when it is raining, and it is simply a good idea.
Perfect.
Great -- I will report my results later this week.
-toy
Old 08-25-2011, 11:13 AM   #4
toy_toronto
always toyin'
Drives: 2010 5-Dr
Came here to report that the auto headlamp feature works! The same sensor detects both ambient light and rain that automatically triggers the headlights when it gets dark out and/or when it rains.
The system allows you to install 2 switches: 1 to bypass rain sensing (comes with the kit), and another switch you need to buy seperately to bypass the auto headlights and disable these features anytime.
Thanks again CTScott!
-toy
ABS and "!" lights are ON again! onizuka Canada 457 04-28-2023 09:40 AM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Anyone Installed Rain-X Wipers? M4One DIY / Maintenance / Service 35 02-12-2010 10:15 AM
