Old 08-16-2011, 04:38 PM   #1
bad_bwoy007
bad_bwoy007's Avatar
Drives: 2010 8T0 Yaris Liftback
2010 Yaris Liftback (LB) / Hatchback - Prewired for Trunk Actuator?
I have a base (no power) 2010 Yaris Liftback. I was thinking of adding a generic solenoid or buying a stock trunk actuator.
Actuator Assembly, Back Door Lock: 69150-52070
Mounting Bolts: 91511-B0614 (2 required)
I was wondering if the 2010 Yaris was prewired for adding this feature?
bad_bwoy007 is offline   Reply With Quote
Old 08-16-2011, 05:44 PM   #2
I believe that it is. You can pop the rear hatch trim to be sure.
Old 08-19-2011, 10:15 AM   #3
bad_bwoy007
Trunk Components
So I popped off the rear hatch cover and here is what I found.
Here is a connector that is not being used. Could this be the portal to unlocking the power of the hatch. LOL.
Old 08-19-2011, 12:30 PM   #4
bad_bwoy007
How does the current power trunk prop open?
Looking at this picture from Village Toyota Parts, I don't see any part that keeps the trunk propped open after the actuator unlocks it.
How do the Yaris' with power package work today? / Is there a Toyota part number for this spring loaded prop?
Its been long enough without this upgrade, I'm ready to place my order!!!
Old 08-19-2011, 12:37 PM   #5
There is no popping. It simply unlocks and then you still have to press the black button in and lift it. To do full popping you would need an aftermarket actuator to pull the lever that the black button hits and a spring assist device.
Old 08-19-2011, 12:48 PM   #6
bad_bwoy007
How about that open connector above in the pics I posted. Would that be the connector for the actuator?
Old 08-19-2011, 12:52 PM   #7
That's for the lock actuator, which does the same thing as turning the key in the lock.
Old 08-19-2011, 12:57 PM   #8
bad_bwoy007
Ok cool. So to add the regular Toyota actuator you can connect it to the open connector under the trunk lid which only opens the lock as if you were using the key.
So you will still need to use the key to close the hatch.
Where can I locate those two wires (gray and pink) under the dash?
So it seems as a mod Yaris owners have two options.
1. Stock key opening actuator.
2. Aftermarket actuator that taps into the existing wires and is linked it into your aftermarket module.
Where can I find some of those spring loaded bump stops?
Old 08-19-2011, 01:17 PM   #9
For unlocking you have the choice of OEM actuator or aftermarket one.
For popping the hatch you need another aftermarket one plus a "trunk popper". Do a google search to find places that sell those. (A1electirc.com sells actuators and may also carry poppers).
The pink and grey wires come into the body ECU (where the under dash fuse panel is) via connector 4A pins 3 (gray) and 4 (pink).
Old 08-22-2011, 10:50 AM   #10
vten
im following this post too ....
I dont need the trunk to pop open ...I just need the capability to lock and unlock it with my aftermarket alarm . are these items all I need to do the task ?
thanks guys
Old 08-22-2011, 11:03 AM   #11
thanks guys
Correct
Old 08-24-2011, 06:40 PM   #12
bad_bwoy007
Mounting Poppers
Thanks CTScott,
So I went ahead and ordered the poppers. One question I have is where would be a good place to mount these things.
There are limited areas to put these.
Any ideas?
Another question I have about the stock actuator, does it open and close the trunk, or just open? (Just need to clarify)
Old 08-25-2011, 02:02 AM   #13
Thanks CTScott,
Any ideas?
I think you'll need to do a bit of experimentation before drilling and mounting the poppers. I am not sure where the best location will be for them.
The stock actuator locks and unlocks (you reverse polarity to the actuator to lock/unlock).
Old 08-25-2011, 11:40 AM   #14
vten
where to order those parts ? stealership ?
thanks
Old 08-25-2011, 01:55 PM   #15
bad_bwoy007
Pricing
thanks
Toyota Parts East Pricing
www.toyotapartseast.com
Retail Price: $115.96 Your Price: $86.38
Retail Price: $0.78 Your Price: $0.58 * 2 = $1.16
Shipping ~ $12.00
Grand Total ~ $100
Not too bad considering if Toyota did the job for you!
Lots of benefits to DIY
Old 09-07-2011, 12:55 AM   #16
vten
How's the project going ? did u install it successfully ?
Old 09-07-2011, 04:03 AM   #17
enviri
enviri's Avatar
Drives: 2010 Yaris
i just want that black button....
looks like either 69215-52060 and/or 69209-52020-xx <--requires smart entry it seems.
Old 12-12-2011, 09:39 PM   #18
bad_bwoy007
Install
The install went very well. I love it, I have not had to use the key in the trunk since the install.
Aftermarket Yaris Hatchback / Liftback RS Spoiler bad_bwoy007 General Yaris / Vitz Discussion 7 04-07-2011 04:05 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 05:07 PM
