Old 10-21-2011, 01:54 PM   #23
Ratz
Ratz's Avatar
Drives: 2011 Yaris 4 Dr. Sedan
Originally Posted by EPyarisdriver View Post
All the tests passed but now Im gonna try checking the relay with the battery and see if I can hear it.
And what I meant is the lights do NOT work.
Sorry for the confusion
Further to what I wrote:
You can test the relay by mirroring the four terminals on the relay when you remove it. Take it to the battery and touch the positive side of relay to positive battery post. Than take a piece of any wire and touch the terminal I referred to in the picture as “Ground controlled by fog lamp switch” to battery negative terminal and you should hear the relay click. If it does not it is likely a failed relay.
Some relays can be really quiet (unusual) so while you are applying power to the above stated terminals and listening for the click, in addition you can connect a ohmmeter to the two remaining terminal. Set the ohmmeter to 200 Ohms scale and watch the gauge while you are connecting relay to the battery. You should see a deflection in the ohmmeter display. If you want to practice what you should be seeing in the ohmmeter display, just with the same setting touch the leads of the ohmmeter together and watch the screen. It should change providing your meter is turned on and battery in the meter is good.
If you used VOM before I apologize for the detailed description.
Ratz
Cleverly disguised as a responsible adult.
Ratz is offline   Reply With Quote
changing reversing bulbs and now other things don't work willygoodness DIY / Maintenance / Service 10 03-28-2012 09:46 PM
Gas Savings Tips That Don't Actually Work! MadMax Fuel Economy Forum 21 03-09-2011 09:25 AM
November: Big Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 14 12-12-2006 10:50 AM
TWM Yaris Short Shifter Sale! TWM Performance Sponsors Classifieds Area 9 08-28-2006 03:37 PM
TWM Short Shifter/Shift Knob Sale! TWM Performance Performance Modifications 0 07-17-2006 05:08 PM
