Old 12-04-2011, 08:24 AM   #3
You can tell if your current ones do by looking at the valve stem. If it is all rubber then they don't. If they have metal where the stem meets the rim, then they do.
My TPWS bypass mod allows an easy method of having a second set of rims without having a second set of sensors. Otherwise, when you swap rims you have to go to a tire place and have them reprogram the TPWS to learn the other set of sensors (our TPWS can only remember one set of four sensors at a time).
http://www.yarisworld.com/forums/showthread.php?t=11058
any tpms swaps out there? steel to aluminum? severous01 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 03-26-2011 07:10 PM
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
DIY - - -TPMS work around rningonfumes DIY / Maintenance / Service 6 03-03-2011 08:11 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
