![]() Drives: hb Join Date: Apr 2011
help with fog install
hi all
i bought a kit from microimage, did the engine bay part ok but i dont know how to proceed in the interior and will really appreciate your help the relay is installed in the right place the switch has 3 cables coming out as the picture. what i need to do with these 3 cables.??? |
DAT'S RIGHT I GOTz 2
http://www.microimageonline.com/down...ts_install.pdf
http://www.microimageonline.com/down...h%20Wiring.pdf
i am using those but im confused... please excuse me as i am rookie on this things
b. For the fogs to turn on with the parking lights, low beams or high beams connect the outside red wire to pin 3 and the green wire next to it to pin 13 of Connector D4, which is the headlight stalk connector red wire? i only have one orange... and it has a strange connector that i dont know how to use. i am supposed to cut the wires? or remove one wire and replace the other? the black one has a different connector it looks like a ground you will connect to a bolt. |
page #8 : your green wire would be yellow in the hareness pic your orange would be red your black is the ground in page#10
thanks i think i almost got it...
1. remove pin 3 cable from D4 connector 2. connect the cable i just removed from D4 and connect it to my orange cable 3.connect my green cable to the pin 3 4. connect ground cable am i correct? i found the 2 set of instructions a litle different... did i receive an outdated switch? woulndt i be missing the connection for the switch light?ç also i would like help on how to remove the pin from D4 connector i tried but i was not able and i was afraid of breaking it. i appreciate all the help at this moment i have my fogs in the bumper but no lights! |
can someone confirm? i think im going to try tomorrow...
#7 | |
#8 | |
http://www.microimageonline.com/down...ts_install.pdf PAGE #4 red wire would need to be extended and routed up to steering column for foglight to be able to turn on with marker,low light and high light
thanks a lot man! i will try it and i hope soon ill post a success picture of my fog lights!!
omg !!!
today i came back from work, open everything... had my paper clip at hand and wasnt able to remove the pin... im afraid of pulling too hard and leaving the connector but removing the wire... any tips? i think i will have to ask a friend who has more experience on cars... |
#11 | |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 08:47 AM |
| Part #s for Fog Light install? Can anyone who works for Toyota confirm? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 73 | 12-23-2010 05:15 PM |
| How to choose and install HID on FOG light | charleschia1986 | Cosmetic Modifications (Exterior/Interior) | 18 | 12-20-2010 09:45 PM |
| Fog Light Install - HELP | GrimlockGT | Cosmetic Modifications (Exterior/Interior) | 1 | 03-19-2010 04:58 PM |
