#1945 |
Only Happy When it Rains
ooh, didn't realize the 16sw was a 6.5. That could work for me. And a pretty darn good price too.
I had the JL 10 in a ported box in the back of the hatch with a full interior. Even with the windows open there was too much sound pressure. I bet you could even kick my butt so I installed it myself. I used to go to school in N Dartmouth, let me know. The lunatic in me is curious to know if you know how much it weighs. Rofl, 7 lbs.
Colin Chapman disciple |
#1946 | |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
why such a low (considering slope) crossover point in a 3 way system? |
#1947 | |
they won't burn... D.
. CLA 250, 4MATIC |
#1948 | |
I like the sparkles from the tweeters above 10kHz up in the a-pillars but I've seen many people go tweeter less. I did try once and it was pretty cool but even pushing the HL-70's I couldn't get them to play high enough. D.
. CLA 250, 4MATIC |
#1949 | |
I also just learned that HA has passive networks (which look pretty awesome) and it seems that they cross the tweeter at around 3500 hz 12 db (5.6 mF capacitor used paired with some inductance) http://store.12velectronics.com/prod...Crossover.html my point is different anyways - just curious why such a low x-over point? |
#1950 | |
some one told me once... "do what ever it takes so it sounds right" and like I wrote once... everybody hears different. My observation when I had my tweeters crossing low, is that it was harder to adjust center image due to reflexions from the windshield and matching with center image on Mids, going back to point source (with Mids) made my tuning easier, sqcomp knows what he is doing for sure and with a purpose. Some times I like the easy way. But that's just me. D.
. CLA 250, 4MATIC |
#1951 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
I have a question...with active filter...and 75W of output on the L1V2...do you need protection ?...75W seems a lot for those little tweeter :S
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#1952 |
you will adjust the signal level at your amp (gain) and use the proper crossover point - this is enough to make sure it serves you long time
#1953 |
Tolmach I hope you're getting more info for that reply you just gave if not it was totally pointless. The guy can't just go and start cranking on dials and everything magically sound good. If I'm right he has 5V preouts we will need to see the input sensitivity on the amp he gets if it's 5V at the min position you have to be very careful with gain. We need a lot more info before we can give advice.
Packet please don't mess with any of your equipment until you fully understand how you are going to tune the amps and set you crossover points, eq's, we will get you a very detailed how to on setting your amp gain. When that time comes we'll need detailed information on your equipment.
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 Last edited by _S7V7N_; 04-25-2012 at 07:31 PM. |
#1954 |
Roadrunner Jr.
Clarification would probably read like this:
Adjusting the gain structure at the source and at the amplifier to not give off a clipped signal from the signal chain as well as a responsible crossover point for the tweeter is the way to go. Think about it this way, Scott Buwalda is using a JL HD750/1 for each L3SE. He's not blowing speakers. I'm working with 240 Watts (@ 12V) on my L4SEs. I'm doing just fine. Why? Refer to the clarified sentence.
To argue with a person who has renounced the use of reason is like administering medicine to the dead. ― Thomas Paine |
#1955 | |
Roadrunner Jr.
I'm actually thinking about shimming my driver's side tweeter to aim to the left ear...just for $hits and giggles. I want to hear what happens with the center image. I've also set up some temporary baffles for the L4SEs just to play around with more aiming that way as well. This is one heck of an experiment between Derick and myself. Between us both, we have some serious R&D time with the front stage acoustics in the Yaris sedan.
#1956 | |
Roadrunner Jr.
Before anyone trys to rake me over the coals, I had Scott Buwalda riding in the Yaris on Monday while on our way to dinner. I showed him the crossover points for all the speakers. He didn't have any issue with 3.15kHz at a 6. If the right kicks it, I'll let everyone know and get Scott to re-work the guts of the tweeter (since it is an L1Pro SE and not a mainline production R2 tweeter).
#1957 |
Roadrunner Jr.
Oh! If I do change the pillar setup, I'll reuse these current pillars and do the entire pillar in ABS to reduce the stress points between the different substrate materials (plastic, fiberglass, filler, and MDF).
#1958 |
Just to add more to the equation, I'm playing the I6SW a (Pmax Rated Power Input of 120 watts) with 400 watts. But Yes... I'm very conservative on volume, distortion and abusing speakers!
I know many people over power, but it's like Sqcomp's sample of the BMW vrs Prius, remember that? D.
. CLA 250, 4MATIC |
#1959 | |
(Bohemian Rhapsody, Keane, queen, garbage, etc.) That's ok, I'll show my car to why? on Friday, I hope he likes the little that can! (i6sw) and no I don't know how much it weights sorry? not much I guess? I'll bring other 2 big brothers too (IDQ12 one of the best SQ subs I've seen it just doesn't fit where the i6sw does, and a Bazooka just to play around) ![]() ![]() D. .
. CLA 250, 4MATIC |
#1960 | |
I'm sure that would give me a head-ache too! I'm going to have to take you for a ride! ![]() D.
. CLA 250, 4MATIC |
#1961 |
Roadrunner Jr.
Completely re aimed my front stage. Changed the crossover points and slopes. Now to get the pillars and kicks redone before June.
#1962 | |
D.
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
