Old 04-25-2012, 10:50 AM   #10
TOLMACH
Drives: soarer
I was going to suggest the sub I'm using as a temp solution, but you said less intensity...
^Yes there's a gap. The slope is at 24dB versus the sub's 36dB.
^And yet another gap. The tweeters are at a 6dB slope.
3.15 khz 1st order for tweeters seems crazily low.. there is also a good chance that you will burn them.. if you want to use the 6db slope my wild guess will be at least 6-6.5 khz (one octave higher)
why such a low (considering slope) crossover point in a 3 way system?
