![]() Drives: Toyota Yaris Join Date: May 2012
Brand new battery drained
I have a 2 month old 12 plate Toyota Yaris T-Spirit with smart entry/start. I went on holiday for 2 weeks, leaving it in my garage and when I returned at the weekend, the car wouldn't start at all. It wasn't especially cold or anything like that while we were away. I 'phoned the dealership and described the "symptoms" and was told that it sounded like the battery had drained and I should call the AA. This I duly did and sure enough, the man from the AA confirmed that the battery was dead and got the car running again.
I've booked the car in for next week and intend to make an issue about this - I suspect, without having checked yet, that batteries won't be covered by the warranty. But surely it isn't right for a 2 month old battery to drain completely after 2 weeks? Has anyone else experienced this? Does it sound like something that "just happens"? Should I be insisting on a new battery at their cost? Thanks for your help. |
Same thing happens to a pair of new GM products my parents own. Whenever they go away for extended periods of time, they need to put a trickle charger on the battery. If they don't, after 2 weeks, they are dead.
It would be interesting to see what the static current draw is for the 2012's with the smart entry system.
The 2nd generation Yaris (without smart entry) draws about 150 mA when powered off, which with its 45 Ah battery means that the battery will be down to 50% of its capacity (what is typically considered the safe discharge level for a lead acid battery) in 12.5 days.
#4 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
[QUOTE=RubySlippers33;644632]I have a 2 month old 12 plate Toyota Yaris T-Spirit with smart entry/start. I went on holiday for 2 weeks, leaving it in my garage and when I returned at the weekend, the car wouldn't start at all. It wasn't especially cold or anything like that while we were away. I 'phoned the dealership and described the "symptoms" and was told that it sounded like the battery had drained and I should call the AA. This I duly did and sure enough, the man from the AA confirmed that the battery was dead and got the car running again.
I've booked the car in for next week and intend to make an issue about this - I suspect, without having checked yet, that batteries won't be covered by the warranty. But surely it isn't right for a 2 month old battery to drain completely after 2 weeks? Has anyone else experienced this? Does it sound like something that "just happens"? Should I be insisting on a new battery at their cost? Two months old! My Sunday bonnet! I would take it straight to the dealer, never mind booking it in. I would insist on written confirmation that the battery has not been damaged and also insist they find and rectify the problem. You have just bought a new car, why should you be expected to tolerate nonsense such as this? Please let me know how you get on with the dealer. Regards Geoff Peace. |
#6 | |
From and analysis I did a while back: In doing some measuring of current draw of various things while the ignition is off I found the following to have the most significant draw while powered off: ECM: 50mA Body ECU: 100mA Radio: 5mA Clock: 5mA Keyless Entry/Remote Starter on my 09: 150mA
#7 | |
2 - The two pictured in my signature picture, which are an 08 and an 09.
Thanks guys. Unfortunately I can't get to the dealership until next Saturday and we all know what it's like pitching up on a Saturday without an appointment! So thought it would be easier to book it in. The general manager is apparently off this weekend but I will 'phone him again during the week and follow Geoff's advice. It's reassuring to know that I'm not the only one who thinks this is ridiculous! Will keep you updated.
#10 | |
#11 | |
I also measured my 2011 Tacoma for comparison, which with power everything, only draws 40 mA. Here are pictures of the measurements: 09 with power package and remote starter (.15 = 150 mA): 09 Power and RS.jpg 08 no power: (.10 = 100 mA) 08 No Power.jpg 2011 Tacoma Pickup with power package (.04 = 40 mA): 2011 Tacoma.jpg
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 02:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 03:40 PM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 10:34 PM |
| Charging voltage for stock battery | Vinceb | DIY / Maintenance / Service | 3 | 02-12-2011 01:10 AM |
| Battery completely drained | YarisOwnersDad | DIY / Maintenance / Service | 16 | 08-21-2009 01:28 PM |
