![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
0-60 in slow
I don't wanna hijack much but this was the explanation that was given to me by a TRD engineer.
When the heads are bolted onto the block the block would distort, and when the heads would be unbolted the block would remain distorted, and since its a race engine it was all built to a specific tolerance and it couldn't be machined or it would go out of spec. You also have to remember these engines were build for IMSA racing so they only need to last for a 24hr race and then they would be replaced. Those motors could make an insane amount of power from a 2.3l reliably but for some reason they have turbo failure issues so you either get lucky or you have a motor that cooks after a short period of time. In case you were wondering they make 900+hp at 31psi only problem is they sound terrible not a nice sounding engine. |
#3 | |
play every day
That's really fascinating information namer. I'm counting on my engine lasting longer than 24 hours. ![]() That Pikes Peak racing engine produced .39 horsepower per cubic centimeter, or over 5.5 times that of a stock Yaris which produces just .07 horsepower per cubic centimeter. ![]() Here's Rod Millen at Pikes Peak... http://www.youtube.com/watch?v=soQsCyr0hTw |
#4 | |
play every day
The first pulls were done with the Blox filter, so my common sense tells me that the second ones will also be done with the same filter. I'm still sticking with the manifold being the only change. USPS tracking had the silicone connector arriving yesterday, so I'll be headed to the Post Office tomorrow after work to see what's up.
#5 | |
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
That will be a good baseline to see if just changing the intake manifold alone will account for any gains/loss
#6 | |
play every day
more on "wrecking" the motor.
It should be pointed out also that you have no way of knowing the long term affects of your manifold on your motor. In fact, you could be feeding one cylinder too much air, or not enough, with a dramatic decrease in engine longevity. If you want to know, I suggest a look at your plugs now and 10,000 miles from now, and a compression test would be a good idea as well. All stuff you can do yourself at no cost.
#8 | |
play every day
It's one thing I really like about this particular design in that it does not possess the inherent runner inequities of the typical log style manifolds which are fed from one end... ![]() ...because all 4 runners share exactly the same relationship to the throttle body. I'm also counting on the fact that this design had already been produced for 4 years and ran on tens of thousands of Corollas over a time span of as much as 14 years. Last edited by tooter; 08-16-2012 at 10:32 PM. |
#9 | |
play every day
#11 | |
#12 | ||
play every day
Sure, Garm. ![]() Post #584 Quote:
Yay. After that, we'll have to get together and have a Vendor's Meeting.
Form>Function
the 6th one can come to Tampa... pending dyno lol
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
ive been waiting for my vender info to come in
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
play every day
Because this is such an extremely small project with a limited market potential and I'm not formally a business, I've already been using YouTube as my point of personal contact because it's free. So I'll be posting some descriptive tooter videos and its intake modification issues, as well as a video of the second dyno runs.
Obsessed with 1.5L
Hey tooter...i was thinking. I think you took my original statement as making your intakes. What i was referring to was of course assembling one for mine using your platea...however i was talking about making a intake to match up to the manifold...and perhaps make a few more for others just to help people out.
#18 | ||
play every day
![]() Of course, that's what the kits will be for. Quote:
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
