Old 05-22-2013, 01:37 PM   #1
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by CrankyOldMan View Post
This is on my to-do list once I get my A/F monitoring under control. I just got a set of 255 cc injectors and a scangauge II this morning and an injen CAI last week.
I really like those big shiny aluminum tube Injen intakes.
I've been looking at this one for the truck as it's the only 4 cylinder one available. I think cold air is an overblown issue. My short ram intake has the same underhood engine/filter relationship and it runs great. When a vehicle is moving, ambient temperature air is blasting through the engine compartment.
This intake enjoys an advantage... if I start messing with the manifold, it's free to move around.
Old 05-22-2013, 01:47 PM   #2
tooter
play every day
tooter's Avatar
Still watching TBR's auction of a Golden Eagle manifold on ebay. Curious to see if there will be any bids.
It's up for a $399 reserve auction with a $699 buy it now.
The reserve is probably $698!
Old 05-22-2013, 04:32 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Sadly, this one is black. There's some dimples in it from rubbing against the bodywork, so I may just lop off the end and make it an SRI a la Tooter.
I still feel compelled to buy one of these things, but the wife isn't really interested in performance mods. Convincing her to put a $450 part under the hood where "nobody" would ever see it would be a really hard sell. Perhaps I could bill it as a cosmetic upgrade? It would have to be purple though...
Old 05-22-2013, 02:01 PM   #4
^ Probably! Ooh... plus $35 shipping.
Injen intake for your truck would be $219.95 through us, by the way.
Part # INJ-PF2011
Old 05-23-2013, 12:11 PM   #5
tooter
play every day
tooter's Avatar
Part # INJ-PF2011
SOLD
I'll drop by with the money around noon today. (order the polished one, and not wrinkle black)
Thanks for the good deal, Garm!
Old 05-22-2013, 03:26 PM   #6
LOL. Let's take a badly designed WeaponR product and put more holes in it. Yeah, ok.
Old 05-22-2013, 08:30 PM   #7
bladesmith6
Drives: 2007 yaris HB
I am tempted to bid for that price just to see what happens.. I'd rather buy from Garm but just can't pull the trigger for full price, I'm stuck in the 80's when manifolds were cheap.....
bladesmith6 is offline   Reply With Quote
Old 05-22-2013, 11:19 PM   #8
Viperoni
Drives: 2005 Toyota Echo
This is interesting too:
http://www.ebay.com/itm/1NZ-FE-Toyot...item35c5efeb74
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 05-23-2013, 11:20 AM   #9
I believe the above one is something similar to what weapon builds for xb
The eBay one isn't just similar, it IS a WeaponR intake. (says so in the text for the listing, too)
He's added NOS ports and a different flange to it.
Old 05-23-2013, 05:43 PM   #10
^ Sorry I missed you today, tooter.
Old 05-23-2013, 07:11 PM   #11
tooter
play every day
tooter's Avatar
I'll see you when the Injen intake comes in so you don't need to bother with reshipping it.
(cool green coupe... )
Old 05-24-2013, 12:11 AM   #12
^ I can always drop it off as well.
thanks, the big 'ol Nash barn find has been a real fun project.
Old 06-01-2013, 01:02 PM   #13
tooter
play every day
tooter's Avatar
Picked up the intake from MI. When I removed the plastic wrapping, I saw that the tube had a manufacturing defect which had nothing to do with either shipping, or Jeff or Garm so I'm dealing directly with Injen.
The tubing was crumpled where the machine gripped it to swedge down the MAF sensor area. Why they went ahead and polished the dents and sent it out is beyond me. Adrian, at customer service is making it right by sending out a good tube that isn't crumpled.
Got the tooter et back from Bill at Ajax Welding...
Now I can mount it on the engine to locate the proper attitude of the throttle body base/bellmouth in relation to the hemisphere.
That manifold on ebay ended up selling for just $250 including shipping which is a pretty good deal for an alloy intake.
Old 06-02-2013, 06:31 PM   #14
tooter
play every day
tooter's Avatar
Put the tooter et mockup on the engine to position the throttle body.
Because the plenum is a hemisphere, the throttle body is free to be rotated and angled in any direction.
I also installed the stock air box as an alignment tool to precisely line up the body for a good fit.
Old 06-02-2013, 08:04 PM   #15
CrankyOldMan
Genius! I'm still curious about how the hemisphere will be mated to the manifold. Or did you cover that already?
Old 06-02-2013, 08:30 PM   #16
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Beautiful work! Does it come with a sound clip?
Old 06-02-2013, 09:59 PM   #17
tooter
play every day
tooter's Avatar
This is the next step... punch a hole to insert the bellmouth.
Hey Cranky,
The plan is to get a round piece of 1/8th inch aluminum plate to fit the hemisphere, and cut out the rounded square shape of the runner retainer.
There will be two welding steps. First, weld the plate onto the manifold runner retainer, and then weld the hemisphere onto the plate. I'll also be inserting three aluminum tubes where the blue dots are for the hoses, so they'll also need to be welded into place.
Old 06-03-2013, 06:03 AM   #18
CrankyOldMan
The plan is to get a round piece of 1/8th inch aluminum plate to fit the hemisphere, and cut out the rounded square shape of the runner retainer. There will be two welding steps. First, weld the plate onto the manifold runner retainer, and then weld the hemisphere onto the plate.
Aah, that makes sense.
Curious-er and curious-er. This thing really is going to look alien when you're done!
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
