Old 06-16-2012, 03:12 PM   #2
You will likely melt the connector and possibly the headlight assembly if you do that for long. It's just a case of a switch that doesn't have a "break before make" mechanism, so you have that small spot where both contacts are powered.
Low Beams not working Karri'es Yaris DIY / Maintenance / Service 7 02-10-2012 08:34 PM
Problem with low beams and High Beams thebarbrr DIY / Maintenance / Service 7 09-22-2010 08:43 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
