Old 12-21-2018, 10:58 PM   #23
IllusionX
Drives: 07 Yaris Sedan Aero
The Yaris is already setup so when you pull the stalk, both hi and low beam are on, but if you push it, then only the highs are on.
Sent from my CLT-L04 using Tapatalk
Low Beams not working Karri'es Yaris DIY / Maintenance / Service 7 02-10-2012 08:34 PM
Problem with low beams and High Beams thebarbrr DIY / Maintenance / Service 7 09-22-2010 08:43 AM
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
