#2611 |
Corporate Slave
Drives: 2010 Yaris YX aka "Cutie" Join Date: Oct 2011
Warranty mo sa electrical will be VOID when you alter or install 3rd party alarm system and/or lights kaya it is your call kung need mo warranty keep it stock kung gusto mo bihisan forget about warranty
Si Vis Pacem Parabellum CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to. Keep your ride rockin and rollin |
#2612 |
![]() ![]() ![]() Drives: Toyota Echo 2005 Join Date: May 2012
Well said by mr.Charliexx.....
#2613 |
![]() Drives: Yaris Y 2012 Join Date: Mar 2012
Mga sir ask lang po magkano mag palagay ng plastic para sa flooring?? And may recomended ba kayo na shop sa Ghurabi Area?
#2614 |
Saan kaya meron Steering wheel Adapter dito sa Riyadh yung universal para makabit ko sa ECHO ko. May nakita kasi ako sport steering wheel kaso wala silang tindang adapter... :(
#2615 |
Corporate Slave
Tol ke Fort sa Ghurabi Manila plaza kaliwa then signal kanan mga 30 meters makikita mo siya sa gilid before nung malaking tindahan ng car accy.
200 paglagay ng plastic and all, ang TAGAL lang....baklas lahat ng bangko mo at make sure and INSIST na i-vacuum ng maigi yung sa akin baboy yung gumawa kaya lalong nagtagal at pinaulit ko, then may nakita ulit ako sa likod pinaulit ko ulit pusa hindi ko siya babayaran kung nagkataon eh
#2616 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: yaris Y 2010 A.K.A. "sky" Join Date: Jul 2010
Ciao !!! Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter) Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way |
#2617 |
![]() Drives: yaris 2008 Join Date: Mar 2012
sir, magtatanong po tungkol sa tire at rim, naka 205/40r/17 po ako 2 times npo akong nagpalit ng gulong sa front driver side kapag kinakabig ko ng full u-turn, dko alam saan tumatama eh sa loob ang butas nya po malapit sa rim na malamin mga 4inches ang haba, saan po kya tumatama yun, at advisable ba na palagyan ko nlng ng hub spacer un pra di na uli mabutas
#2618 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan 2010 "shadow" Join Date: Mar 2010
#2619 |
Corporate Slave
ah hindi plastic lang yung sa akin, yung ke Mike mcdo na may rubber eh sa kisame ata yun not on the flooring.
#2620 |
sir syntax, check ko uli ung offset ng rim ko
#2621 |
Corporate Slave
kamusta
#2622 |
#2623 |
Corporate Slave
Syntax ok ba sigline ko.
Yan ang official sub group ng PINOY YARIS OWNERS SA MIDDLE EAST......TAKE NOTE NOT RIYADH PERO MIDDLE EAST as in GCC, Iraq, Iran, Syria, Yemen, Dubai, Jordan, Kuwait at iba pa
#2624 |
#2625 |
Corporate Slave
tol email ko syo
#2626 |
Corporate Slave
ano nga ba email mo joni he he he
#2627 |
amoy sunog
Mga kayaris ask ko lang po kung may nakaexperience rin ng pangangamoy sunog kapag nasa high RPM. pina check ko sa toyota service center di nmn ma-trace. Ang amoy e parang ung ginagamit sa pangkulot ng buhok....any idea mga kayaris? thanking u all in advance.
#2628 |
Corporate Slave
Hindi ba amoy clutch, baka naman naka babad ang clutch mo or baka mababa na ang pedal mo at may sabit ang clutch mo
