Old 08-20-2012, 09:10 PM   #667
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
There won't be any turbulence issues with such a smooth oversized parabolic profiled entrance. Half of the Weapon R intake curve is actually inside the 90 degree fitting to smooth the transition, and the relationship of the throttle body to the MAF sensor remains unaltered.
That's the main reason I like the BLOX velocity stack/filter so much. None of the other intakes are quite like it.
Old 08-20-2012, 11:01 PM   #668
^ That air is passing through a sharp 90 degree bend RIGHT before the MAF. Your smooth air argument is a little weak because of that.
Old 08-21-2012, 01:02 AM   #669
tooter
play every day
tooter's Avatar
There's nothing to argue, Garm...
...as this is only an experiment to see what happens when I continue to follow my genuine interest while trusting my own common sense in exactly the same way it got me started in this venture. So it's totally understandable that this isn't necessarily going to make any sense going "outside the box" of conventional methods...
...but the real fun is finding out what happens when I do.
This is why I'm interested in flow dynamics...
http://www.youtube.com/watch?v=Sgx4G4uli_w
http://www.youtube.com/watch?v=wE34Ho2jzrM
Old 08-21-2012, 01:33 AM   #670
ljming99
Drives: Yaris '06
Yeah, its a tad sad that the stock air box cannot be reused exactly to make it as close as possible to a plug and play kit. That also made the air intake a custom kit.
I suggest you bundle the entire kit as the final product =)
ljming99 is offline   Reply With Quote
Old 08-21-2012, 01:47 AM   #671
tooter
play every day
tooter's Avatar
Yeah, it's because the manifold is a completely different design from the stock one. To tell you the truth, I never even tried the stock air box because the throttle body is moved so far to the right. I'll take a closer look just to see if there is a way to mod the box to fit.
You have a good idea there...
It might be nice to at least offer that option. Malibuguy had expressed some interest in fabricating a matching intake. If he decides he doesn't want to, I'll see if I can come up with something a little easier than fitting that big BLOX air filter into such a small space.
Old 08-21-2012, 02:12 AM   #672
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
You also have to realize that engine flow isn't static ie its not a constant suck its more of a pulse so the short inlet is likely going to introduce turbulent air into the maf and since the maf reads air moving in any direction whats going to happen is the motor "might" develop weird lean spots in certain areas of the curve. A number of aftermarket companies have run into those issues because their inlet is to close to the maf.
If you have a copy of solidworks I suggest you play around with the flow simulation tools. Here is a video of it, its a cool tool.
http://www.youtube.com/watch?v=X3ecq...eature=related
Old 08-21-2012, 10:07 AM   #673
1. Jeff provides helpful references, including information about turbulence.
2. You "argue" (what other word would you use?) that there won't be any turbulence issues.
3. I point out the 90-degree bend right before the MAF as a cause for turbulence. (Which I have some experience with).
You're right, it's not an argument -- it's a difference of opinion.
Old 08-21-2012, 10:21 AM   #674
tooter
play every day
tooter's Avatar
And that's what life's all about... finding out.
Old 08-21-2012, 05:13 PM   #675
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
while finding out your learn much more then when someone tell you not to do this or that :) thats my 02 cent
Interior:ALL red, black roof
Old 08-21-2012, 05:51 PM   #676
^ Of course. It's an experiment, we're all clear about this. Not knowing what affect turbulence might have is one thing, and it's the truth -- none of of us know for sure, including me.
But stating as a fact before it's known that there won't be a problem will elicit a comment from me -- every time. Just as I'd hope you would do if I were to make such a claim.
Old 08-21-2012, 06:53 PM   #677
packetrace
packetrace's Avatar
You are right...
Old 08-21-2012, 07:39 PM   #678
anomoly40
Depot Damager
Drives: '08 Liftback
Im just here for the ladies. I dont care if it makes power or not.
anomoly40 is offline   Reply With Quote
Old 08-21-2012, 09:49 PM   #679
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
We'll all find out, win lose or draw, on Thursday.
Maybe try with the filter as is and with just the velocity stack straight on like you had it before and see if there's any difference. That should only take 30 seconds to change over.
Old 08-21-2012, 09:52 PM   #680
@ anomoly40:
Old 08-22-2012, 12:26 AM   #681
tooter
play every day
tooter's Avatar
You got that right, pack... I'm a find out for myself kind of guy.
With little education, I rely instead on my common sense to teach me what I need to know by actual experience, and learn as I go.
I was told that I couldn't build a home on the land I bought, so I built a home on it without a mortgage.
I was told that it was impossible to get a job, so I started a business at the worst possible time, right in the middle of a bad recession over 30 years ago, and have made a decent living for decades and continue to prosper even in the midst of this recession.
I was told that the Corolla manifold would not be driveable on the Yaris at low rpms because it was too large, so I found out for myself that the engine starts right up, idles like butter, drives great at low rpms, averages 38 mpg, and has never triggered a CEL light.
People mean well when they say you can't do this, or you can't do that, because in their own experience they couldn't do it themselves. But I have found that not everyone's experiences are the same. That's why I'm a find out for myself kind of guy...
...because the fun is in finding out.
Old 08-22-2012, 01:00 AM   #682
tooter
play every day
tooter's Avatar
It will very likely be a combination of all three...
Some winning points,
some losing points,
and some same points.
Just changing a manifold isn't magic.
Old 08-22-2012, 09:28 AM   #683
^ no, but your ability to create a 40 page thread for one is.
Old 08-22-2012, 12:35 PM   #684
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Good luck tomorrow, Tooter!
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
