Old 02-13-2013, 02:34 PM   #1
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
NPT plugs are for the threaded holes in the bottom of the manifold
10" PCV hose is to replace the short factory hose from the head to the manifold (this will be easy to identify when installing, it routes to the middle spout on the manifold)
The two outer spouts will re-use the factory hoses.
The two bolts, spacers and washers are used to space the radiator hose bracket away from the first intake runner. Let us know if any of this is unclear.
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 02-13-2013, 09:43 PM   #2
mr_miles
Drives: 2013 Yaris
We have some of the same days off - We should meet up and I'll help you install it! (PM me if that's something you want to do) :)
Old 02-14-2013, 05:39 AM   #3
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
Mr Miles: I'll be working on it most of the day Friday at a friend's place, I'll PM you my number and if you're interested in coming out and taking a look or helping out, it shouldn't be an issue.
I have a question about the thermal gasket, do you install it directly against the head or does there need to be a o-ring gasket between the head and the thermal gasket? From the reading online it looks like I shouldn't need one but I thought I'd ask first.
4/20 NEVER FORGET is offline   Reply With Quote
Old 02-14-2013, 10:07 AM   #4
^ No, the O-ring goes in the manifold groove (or O-rings on the new mani), the head surface is flat I believe.
Old 02-14-2013, 12:11 PM   #5
^ Thanks, that just about covers it. Some roughness on the intake side is acceptable, it's smoothness on the exhaust side that is important.
Old 02-14-2013, 05:29 PM   #6
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Yes. That slight roughness is negligible and purely cosmetic. Mine needed grinding exactly the same way.
Old 02-14-2013, 03:53 PM   #7
4/20 NEVER FORGET
Ok cool. I figured I'd still need the Orings on the manifold, I was just wondering about between the thermal gasket and the head. It looks like people are just installing them flat against the head. Thanks!
Old 02-14-2013, 04:34 PM   #8
jetblast
Drives: Gen 1 XB
Wow! That unit is sooooo much nicer than the Weapon R manifold. Quality pieces are well worth the wait.
Why strive for a JDM BB, when you can promote the Scion badge?
jetblast is offline   Reply With Quote
Old 02-14-2013, 06:13 PM   #9
skeck
keckbot
skeck's Avatar
Drives: 2007 Blazin' Blue Liftback
Intake Mani Installed!
Got mine installed and oh by the way...FS stock intake manifold for Yaris.
skeck is offline   Reply With Quote
Old 02-14-2013, 06:18 PM   #10
jetblast
Drives: Gen 1 XB
Damn sharp Skeck, both inside and out!
Old 02-14-2013, 06:21 PM   #11
skeck
keckbot
skeck's Avatar
Thanks man!
Old 02-14-2013, 06:46 PM   #12
Jeff@MicroImage
"Know it all"
Looks great! Pretty sure you're the second automatic to run one and at least one other is running the Injen CAI, looking forward to your feedback after some more driving :)
Old 02-14-2013, 06:48 PM   #13
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
I can't remeber, do you change over the electronics with the 1zz Throttle body or do you just plug and go faster?
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood
Old 02-14-2013, 06:52 PM   #14
skeck
keckbot
skeck's Avatar
I swapped the electronics myself.
Old 02-14-2013, 07:13 PM   #15
tooter
play every day
tooter's Avatar
Gooks super, sheck!
Have you driven it yet? And did you need to turn down the 1ZZ idle screw?
Old 02-14-2013, 07:32 PM   #16
skeck
keckbot
skeck's Avatar
Drove to car wash and back but no freeway yet...due to rush hour...No I didn't adjust idle screw. I actually installed the throttle body about 6 months ago or so
Old 02-14-2013, 08:28 PM   #17
tooter
play every day
tooter's Avatar
If you installed the 1ZZ 6 months ago and aren't complaining... then it didn't need to be turned down. So how does the car drive? Do you notice any difference?
Old 02-14-2013, 10:11 PM   #18
skeck
keckbot
skeck's Avatar
First Test
Okay, So I just got done with my first freeway test...and OH MY! The mid and even high range pull is amazing...definitely a noticeable difference...Before I knew it I was up to 95 with ease and before this MOD it took WOT for a bit to get even close...For N/A folks All I have to say is BUY ONE!!! Now, keep in mind I have the following MODS as well... Throttle Body Swap, Weapon R Throttle Controller (Which I always keep on highest setting), Nitto Midpipe (Cat delete), DC Sports Exhaust, DC Headers, Injen CAI, Micro Image Crank Pulley and removed the following weight (Passenger Seat, 60/40Back Seat, Spare Tire Cover). I still need to get my Camcon tuned which is running in bypass mode right now, so I will keep everyone posted on dyno numbers when I get that done. But huge noticeable difference is what i have to say. I am still grinning ear to ear and I was literally laughing uncontrollably while I was driving. Again...BUY THIS!!!
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
