play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Those dyno runs were as accurate a comparison as I could make. Each successive run reflected only one change at a time (first a manifold, and then a throttle body) with everything else exactly the same. +3/+1.5 is pretty good for a throttle body.
#2 | |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
Especially when you consider the cost of the throttle body!
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
play every day
Yes.
![]() And I just paid the going rate $125. That's pretty cheap power. |
My Face Is Ridiculous
Drives: 2010 Toyota Yaris 3dr LB Join Date: Dec 2011
I've seen them used as low as $45
play every day
I know. But the cheap ones either look like they had the crap beat out of them or that they were flood salvage and I didn't want to take a chance. The one I got came like this with the dirt scraped off...
![]() After stainless steel bead blasting it looks like this... ![]() ...and it performs flawlessly. Hey, how about posting some more MI manifold pictures? Who else here has one? (Sorry for jacking your thread, Garm. The 1ZZ should have its own thread. Is there a mod here who could move it?) |
important question Garm, what is the weight difference between the stock manifold and the Micro Image one? thanks.
or just what is the weight of the new item? if you don't have a stock one laying around to weigh I'm sure somebody does. |
Stock intake is 5.40 lbs.
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
A couple other shots I have from installing the manifold:
![]() ![]() As you can see it's pretty snug toward the front of the car. I had to take off the hood latch to get it in there without scratching up the runners. Mmm manifold porn. |
another install:
Removing the hood latch is a good idea. You could also blue tape it thoroughly, or tape a shop rag over it.
still no weight on the new manifold?
play every day
It's made of aluminum. I'd guess it a few more pounds than stock. It's negligible.
#14 | |
All shipped, I can't weigh one until the next batch comes in. I could've sworn I weighed one, but I can't find the number. It's a negligible difference, maybe 1-2 pounds more than stock.
Micro Image forums, online store and shop are now closed. It was a great eight year run, but it was time to focus on other things. I'm still selling parts on eBay under micro*image seller ID and customers can still make requests for anything specific. Last edited by cali yaris; 02-21-2013 at 02:28 PM. |
#15 |
just curious, I like numbers :)
#16 |
another good question, how is the positioning of the throttle body as compared to the stock piece? the reason I ask is because I'm not running an SRI or CAI, just the stock box with a TRD filter in it and I'd prefer to keep the stock intake box....but if it has to go I'd like to know about it in advance.
#17 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
If you have/want to swap out your stock box, I have a filter sitting in a closet going unused I'd like to get rid of...
As it is, I'd certainly encourage a more open intake (and ideally TB) as you can REALLY hear the engine, and it's amazing.
#18 |
Our intake manifold works perfectly with your stock airbox. We were very careful to make this happen (one reason it took a couple extra prototypes). The throttle body isn't EXACTLY in stock position, but your stock flexible intake hose will make the adjustment just fine.
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 01:06 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| Yaris Intake Manifold | richardholdener | Performance Modifications | 201 | 05-18-2009 11:58 AM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 08:03 PM |
| Official Richard Holdener *MID-RANGE* Intake Manifold List | WolfWings | Performance Modifications | 59 | 11-13-2008 11:26 PM |
