Old 08-29-2012, 01:44 PM   #1
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
I seriously can't wait to buy one. I haven't been this excited about something on this forum ever. Keep us updated!
4/20 NEVER FORGET is offline   Reply With Quote
Old 08-29-2012, 01:46 PM   #2
^ I like the coating results so far. Here is another motor I'm building.
I used to use Jet Hot (the actual brand name) and ship stuff out, but I get the same results from the local coater.
Old 08-29-2012, 01:58 PM   #3
Jason@SportsCar
That must have taken some real self control for you... Knowing that Jet Hot offers its coatings in green.
Old 08-29-2012, 07:33 PM   #4
packetrace
packetrace's Avatar
Drives: Yaris Sedan 2009
what is that engine ??
I have the same engine stand
Interior:ALL red, black roof
Old 08-29-2012, 07:46 PM   #5
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Looks like an engine from a datsun 510.
Old 08-29-2012, 08:03 PM   #6
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Originally Posted by Golddeenoh View Post
just so everyone knows, I want a red one, and you said you would make it. :D
Red is no problem, the problem is choosing which red
We have several options for coatings, including but not limited to:
red anodizing (several shades from bright to dark)
red powdercoating (10+ color choices including glossy, candy, pearl, semi-gloss, matte, etc..)
red high heat wrinkle or flat powder coat
red thermal coating
Originally Posted by Bluevitz-rs View Post
Is there going to be a 3 bolt TB option? Is it at all possible to make the mounting flange universal to fit either TB?
We have flanges for 1NZFE Echo/xB/xA already, as well as for aftermarket larger bore throttle bodies. Just need to specify at time of order.
U20 going into 1969 Datsun Roadster
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 08-29-2012, 09:48 PM   #7
Golddeenoh
Takes corners too fast!
Golddeenoh's Avatar
red thermal coating
Either as close to the body color as possible or as close to the Tanbe strut tower brace and AEM CAI. (I have put the rest of the Radiator hoses on since this photo and added the Grounding kit)
Old 08-29-2012, 02:39 PM   #8
thefalls
Drives: Axio GT
This is a great product. Looks the part!!!
Awaiting the results impatiently.
And the question is,how can it fit in here? :)
thefalls is offline   Reply With Quote
Old 08-29-2012, 04:13 PM   #9
thefalls
Drives: Axio GT
Dont have a picture of my own engine bay,but this is the same engine and intercooler piping.
Old 08-29-2012, 04:43 PM   #10
I've re-invented myself - now I'm all business, baby.
Old 08-29-2012, 07:27 PM   #11
4/20 NEVER FORGET
Old 08-29-2012, 08:26 PM   #12
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Thats an awfully large collector for that motor...its going to shift the torque curve upwards thru the roof
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-29-2012, 10:11 PM   #13
not that much, the runners are super long and the motor has a lot of torque. The U20 revs to 7000+ easily. It's in the car now, getting tweaked and tuned.
Old 08-30-2012, 06:03 PM   #14
Jeff@MicroImage
"Know it all"
Red anodizing will match the Tanabe and AEM pieces
Red Powdercoat will match the body color and rad hoses better
We'll quote you on both options when it comes time to order.
Old 08-31-2012, 07:02 PM   #15
bump. 200+ miles, no problems so far.
{{{{ DYNO NEXT THURSDAY }}}}
Old 08-31-2012, 08:37 PM   #16
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Hope it's cool that day!
Try for first thing in the morning. My day ended up being be fairly hot at 88 degrees.
Old 08-31-2012, 10:03 PM   #17
^ We'll be dyno-ing with and without the manifold during the same session (and possibly with the 1ZZ throttle body as well), so it won't matter what the temperature is in order to compare differences.
Old 08-31-2012, 10:05 PM   #18
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
how will you overcome the "learn" function for both dyno pulls?
Or will you simply reset the ecu before each pull?
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
