Old 08-31-2012, 10:15 PM   #1
^ At WOT it won't matter, there isn't any ECU "learning" in open loop.
It does learn your "style" etc. for regular driving/partial throttle/cruising; that's what we've been testing this week.
Old 08-31-2012, 10:30 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
oh ok :)
Old 09-03-2012, 11:04 AM   #3
Jack Yak
Drives: Yaris 1.3 07
looks great ;)
it is 2" inches isn't it ??
... waiting for the dyno
Jack Yak is offline   Reply With Quote
Old 09-03-2012, 01:02 PM   #4
Astroman
Modded Moderator
Astroman's Avatar
That's what she said.
Old 09-03-2012, 06:26 PM   #5
swidd
Drives: Yaris HB
Will this fit with the aFe intake? $$?
swidd is offline   Reply With Quote
Old 09-03-2012, 06:30 PM   #6
^ We don't know the price yet, and we haven't tested it with any aftermarket intakes. What you see in the thread is everything we know and have done so far.
If the dyno shows some power gains, we will further refine the design if we can to fit the stock or aftermarket intakes to the manifold.
Old 09-03-2012, 07:26 PM   #7
chaditotx
Drives: 2007 3dr hb 5sp
Those J Bend tubes are super sexy. sure beat the plastic composite look.
chaditotx is offline   Reply With Quote
Old 09-03-2012, 08:24 PM   #8
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
I'd buy it even if I had to modify the factory/aftermarket intake. Maybe include a intake with a diameter tube that matches the 1zz tb with a mount for the MAF sensor? Eagerly awaiting this to go up for sale.
4/20 NEVER FORGET is offline   Reply With Quote
Old 09-03-2012, 08:47 PM   #9
^ Good ideas. Dyno session is Thursday, after that we'll figure out what we're doing next.
Old 09-03-2012, 09:11 PM   #10
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
What is it with these intale manifolds all being dyno'd on thursdays???!!!
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-03-2012, 09:29 PM   #11
Because it's the best day.
Old 09-03-2012, 11:11 PM   #12
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
good luck Garm
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 09-04-2012, 01:01 AM   #13
g.q.vios
jqueza@microimage
g.q.vios's Avatar
Drives: 2010 vios
ill be waiting for thursday results cant wait!!!
g.q.vios is offline   Reply With Quote
Old 09-04-2012, 07:46 AM   #14
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
2 DAYS!!!
Old 09-04-2012, 02:34 PM   #15
baseballfan416
Drives: 2017 L 3-door
I wonder if changing the intake manifold gasket to a non-metal material would help? More metal (compared to the plastic manifold) could translate to some heat soak?
baseballfan416 is offline   Reply With Quote
Old 09-04-2012, 03:13 PM   #16
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I do believe that it would...
I did the dyno runs without it and the manifold was blazing hot. That big one inch thick slab of aluminium "heatsink" laying across the intake ports transfers engine heat like crazy. I'm going to get longer bolts to put the insulating gasket on.
Old 09-04-2012, 03:10 PM   #17
suckerface
#1 Lemming
suckerface's Avatar
Drives: Light Blue '08 Yaris
If I understand intake properly, you'd want more heat soak. Intake air temps you want to be lower, exhaust should be warmer. Heating the intake temps will rob some of the power (hence why cold-air intakes provide more power over short-ram and OEM)
Anyone feel free to correct me if I'm wrong.
:EDIT:
Completely misread, and didn't notice the "gasket" portion of what was said. Thought you meant the ENTIRE manifold...
I'll go back to my corner now
Old 09-04-2012, 04:42 PM   #18
^ The manifold will get pretty hot from regular driving, especially stop and go, or "around town". Once you are moving pretty well, the longer runners will help protect against too much heat transfer.
The insulator/spacer might help a little. I'm not sure we'll be able to test one on the dyno though.
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
