Old 11-15-2012, 09:11 PM   #3
Yaris Lighter
Drives: Red Yaris Sedan '07
So, the HO doesn't have the pink "M" wire? That wire goes to the ECM and the A/C ECU as a signal that tells them if the alternator is outputting power, so they know if it is OK to run various high current functions.
In your case, you would now just cap that pink wire off.
Thank you so for your reply Scott! I shall do just that!
But I just want to double check.
Will I then have a problem with the ECM and A/C ECU not receiving that signal or will it not really effect anything worth worrying about?
Yaris Lighter is offline   Reply With Quote
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
factory speaker wiring question. Domosofly In Car Entertainment + Electronics (audio / video / alarm) 5 06-25-2011 12:35 AM
WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack zerosktz Willing to Buy by private party 4 02-19-2011 02:41 PM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 11:43 AM
Wiring color code for 2008 LB? charles nelson DIY / Maintenance / Service 0 04-25-2009 03:56 PM
