#6 | |
My bet is that the alternator is generic, so I would not hook up the extra wire to the M terminal unless the alternator manufacturer can confirm its purpose. I would also not move or combine wires. They are labeled, so verifying that the labeling is correct should be done with the manufacturer as well. The low voltage on the L wire does explain the idiot light not working. The low voltage on the second run almost makes it sound like something already failed within the alternator, since you are reading battery voltage, rather than a higher output voltage from the alternator. Check the two large fuses on the positive battery terminal red plastic chunk to make sure one of them did not pop.
| Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | 06-10-2024 10:06 AM |
| factory speaker wiring question. | Domosofly | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 06-25-2011 12:35 AM |
| WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack | zerosktz | Willing to Buy by private party | 4 | 02-19-2011 02:41 PM |
| Wiring Pictures | MitchEvious | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 12-28-2009 11:43 AM |
| Wiring color code for 2008 LB? | charles nelson | DIY / Maintenance / Service | 0 | 04-25-2009 03:56 PM |
