![]() Drives: Yaris 2006 Join Date: Jan 2011
ok good, thank you very much and keep looking to see if I can get the SPF5014 integrated circuit which is the piece that has a bad module card
#2 | |
The part number is different (88650-52291), but based on my experimentation, I believe it would work for you (I tested it in a US Yaris and it functioned properly). In a worst case you could transplant the SPF5014 from it to yours.
Drives: Toyota yaris sedan Join Date: Aug 2017
No enfria en baja
Buenas tengo un problema tengo un yaris sedan 2007 cuando el carro esta parado no enfria el aire pero si lo acelero un poco empieza a enfriar alguien sabra el por que? Me disen que puede ser la poa pero que quisas no! Alguen que me pueda ayudar
| falla en aire acondicionado | frank_0124 | Central and South America | 4 | 07-28-2013 07:54 PM |
| TENGO UN PROBLEMA casi serio con el carro | ryas | Central and South America | 18 | 11-07-2011 03:22 PM |
| problema con fog light hid | rene0023 | Caribbean | 29 | 11-25-2010 02:12 PM |
| problema con yaris | yaris_trd | Caribbean | 44 | 09-14-2010 10:28 AM |
| Filtro del Evaporador del Aire acondicionado | joseorellana2012 | General Yaris / Vitz Discussion | 2 | 07-17-2009 07:41 PM |
