やりすぎだ~
Taillights for 2012+ model
JDM Toyota Vitz taillights for 2012+ (Non-RS model). They are used but in very good condition. You will have to use your existing plugs and bulbs since they are not included. I've tested the four LEDs in the housing itself and they all work. You'll also have to wire them in yourself if you want to utilize them. $358.00 shipped to anywhere in USA.
![]() JDM Toyota Vitz taillights for 2012+ (RS model). They are used but in very good condition. There is a connector with pins that connect to all the lights. You'll have to use your existing wiring to connect them. You can get the female plug from Toyota to connect it like OEM if you like. I've tested all the lights - they all function and are included. Filament bulbs are in turn signals and reverse lights. LEDs are parking and brake lights. $498.00 shipped to anywhere in USA. ![]() If you ever wonder why the price is "so high", think about the dollar to yen conversion rate and you'll understand why. Still, it's a little cheaper than what you saw on eBay because I actually packed them into my suitcases and brought it back with me from Japan. You can do the same when you go to Japan. I'll might post it on eBay later (at a higher price) but felt the Yarisworld community should get first dibs if anyone is interested... or just look at the pretty pictures ![]() (PS: Please don't ask me if I can get other things from Japan because I can't.) |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
You in Hawaii?
Cheapest DD I could find!! |
![]() ![]() Drives: 2012 Toyota Yaris Join Date: Sep 2012
So are these lights actually Made in Japan ?...
![]() ![]() ![]() ![]() Drives: 2013 Yaris Join Date: Oct 2011
owihdsjkdfs I want the RS ones. If you still have them later when I can afford them, I want them lol.
やりすぎだ~
no show, no go :(
lol... god i wish they were more affordable. someone PLEASE make a knock-off!
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
The RS lights are not plug and play?
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
ThatYarisGuy
Drives: Toyota Yaris 2012 SE Join Date: Oct 2012
i see your ad on ebay. i saved you.
やりすぎだ~
You'll need the plastic female housing to mate to the one shown in the picture. Then you can carefully remove the pins from your existing housing on the harness and re-use them in the new housing. Then it would be plug & play. I did the same thing with my 2008 Yaris.
Yeah, cheaper here if you're a Yarisworld member.
#10 | |
![]() ![]() Drives: Betsy - 07 Yaris HB Join Date: Sep 2011
I guess ill be waitkng in line for the rs type one! I need the funds! KAMINARI!!
WILDY imaginative WONDERFULLY expressive
| JDM Vitz taillights (non-RS) model - new to me. | yarisugi | Third Gen Yaris General Discussion | 2 | 12-15-2012 04:20 AM |
| Hella taillights installed | Brian | Cosmetic Modifications (Exterior/Interior) | 20 | 09-18-2011 11:41 AM |
| Most Reliable Makes of 2010 | 2007yariz | General Yaris / Vitz Discussion | 16 | 12-02-2010 03:37 PM |
| Yaris from New Zealand model - some differences to Canadian RS Yaris model | Super_BQ | General Yaris / Vitz Discussion | 0 | 07-23-2007 02:54 AM |
