Old 01-16-2013, 04:06 PM   #11
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
You might want to maintain required coolant levels to the best of your ability until a new waterpump can be installed, that picture of the spray mark makes me think if the coolant is coming out that fast i'd probably not drive the car as you could possibly run out of coolant entirely in a few miles.,
i'll presume with that amount of coolant loss that its spraying from the waterpump gasket that theres a large puddle of coolant under the car if parked for a while?..
Have Yaris will travel..
DIY waterpump RnR kou DIY / Maintenance / Service 86 03-05-2016 01:15 AM
OEM roof rack mounting rubber pad replacement Yai Cosmetic Modifications (Exterior/Interior) 3 12-22-2012 12:01 PM
Shock and Struts Replacement... New Tires Blowtorch DIY / Maintenance / Service 3 07-25-2012 12:44 PM
Single Tire Replacement - Using Pressure Sensor? 1stOne Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 09-13-2010 10:25 AM
