Old 01-17-2013, 12:46 PM   #10
iacubovici
Drives: Yaris 2008
different ECM
Hello, I want to do this on my 2008 YarisHB, I made the 4 switch assembly, I found the D3 connector but the problem is that my ECM is BOSCH and the A21 plug is different. Is bigger with twice the number of pins and I don't know where to put the wire that had to be in the nr 40 pin on the A21 connector. Any suggestions? And I saw that I have 2 switches on my clutch peddal: on that works when tha clutch is pressed, witch is used to start the car because mine has the Start&Go button, and there is another switch near the stop bolt, so I guess I dont't need to buy this switch anymore.
iacubovici is offline   Reply With Quote
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
