Old 01-08-2013, 02:12 AM   #1
jyijahn
Drives: Yaris
Unhappy Very low MPG, plz help
Hi guys,
I just bought this 2008 Yaris. Had a full tank of gas from the dealer. I set the trip recorder to 0 when i left dealer. I lost the first bar on the gas gauge when I had only driven 37 KM. I searched other posts on this forum. Many ppl posted they drive about 70 to 100 miles, which is 112 KM to 160 KM, for the first bar.
Should I send this car to dealer to check it right away? What could be the problem?
Thanks a lot.
jyijahn is offline   Reply With Quote
Old 01-08-2013, 02:23 AM   #2
edmscan
edmscan's Avatar
Drives: 2020 Corolla
I was getting about 95 km on the first bar on my 2007 Yaris in the summer time .. but in the winter time it is much lower than that. But you being from Vancouver .. I wouldn't think that you would see as much as a drop as you guys really don't have the same winter problems as we see in Alberta. But 37 km does seem a little low to me.
edmscan is offline   Reply With Quote
Old 01-08-2013, 02:41 AM   #3
Yaristeve
Drives: 3-door hatch
First of all, are you sure the tank was full? Did you see them fill the tank or did the dealer just point to the fuel gauge and say the tank is full ("See? all the bars are lit!")? The first bar will stay lit even after a few customers' test drives; the tank may have been down a gallon by the time you took ownership. Refill the tank and try it then go to the dealer.
Oh, I get about 70 miles on the first bar driving normally, cruise control set at 70MPH.
Old 01-08-2013, 08:38 AM   #4
NEexpat
Drives: 2009, auto, 4dr LB
I'll mention it anyway, make sure you are in "D" and not "3"
NEexpat is offline   Reply With Quote
Old 01-08-2013, 09:03 AM   #5
bronsin
bronsin's Avatar
Fill the tank to the CLICK of the gas pump.
Drive 250km.
Fill it again to the CLICK.
Do the math.
THATS your mpg km/l.
Old 01-08-2013, 09:43 AM   #6
NEexpat
^lol, hey Bronsin that's my usual stock post on these mpg threads. Only I would suggest they drive it all at once.
cheers.
Old 01-08-2013, 09:53 AM   #7
jyijahn
Drives: Yaris
Thank you guys so much. I think I was driving it in 3 not D lol, dumb of me, didnt pay attention. But i am so thankful for u guys helping me with all these useful info. I will test the fuel efficiency again.
Old 01-08-2013, 10:01 AM   #8
NEexpat
^Not uncommon, welcome, enjoy your car.
cheers.
Old 01-08-2013, 11:40 AM   #9
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
this winter i've only been getting 79-94 for the first bar, summer i usually get 89-110 & low 120s when i'm hypermiling
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-08-2013, 03:28 PM   #10
mr_miles
Drives: 2013 Yaris
the fuel gauge in my 08 read incorrectly, it dropped the gauge fast. i would hit the last bar at around 270 miles, even if i was getting 46mpg lol
Old 01-08-2013, 11:06 PM   #11
nookandcrannycar
LOL. Not hard to picture a salesman saying "See? All the bars are lit!".
Old 01-09-2013, 12:53 PM   #12
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
Also check the tire pressure. When I picked mine up the pressure was only 27psi. (perhaps to soften the ride for test drives) The warning light does not trigger until the pressure is 25psi. After the first week of driving I checked the tires and increased all 4 to full 32psi pressure.
SpaceShot is offline   Reply With Quote
Old 01-19-2013, 07:16 PM   #13
charles nelson
Drives: red Liftback
The 'first' click on the gas pump is not necessarily the same on all pumps. It is there to automatically shutoff the fill. I have had different pumps auto-shutoff at different fill levels. To be sure that I have completely filled the tank...I very carefully and gently hold down the trigger until I can see gas at the neck. Some stations and states will charge you a nasty cleanup fee if you trickle even a drop of gas on the pavement.
charles nelson is offline   Reply With Quote
Old 01-19-2013, 07:52 PM   #14
jayeh
Drives: '08 Yaris LB
I usually get about 90-160 km on the first bar! So, it varies big time.
jayeh is offline   Reply With Quote
Old 01-20-2013, 02:46 AM   #15
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Originally Posted by jyijahn View Post
Hi guys,
Obviously the tank wasnt completely full but was full enough to get 37km before the first bar disappeared. tell us how many kms you get when you fill it up for the first time..
Have Yaris will travel..
Old 01-20-2013, 12:27 PM   #16
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Guessing at gauge bars and clicking gas nozzles just doesn't cut it. If you want to accurately measure your gas mileage, simply log your distance travelled off the odometer, and how much gas you buy off the pump indicator every time you stop at a station.
Then add up a few of them (not just one) and divide the combined distance by the total amount of gas and then you will know exactly what mileage you are averaging.
Anything less is just guessing...
Old 01-20-2013, 09:14 PM   #17
lol
How about adding up 90% of all gas receipts. lolol
Old 01-20-2013, 09:48 PM   #18
tooter
play every day
tooter's Avatar
lol
Ah, you're singing my favorite song.
Engine fan on when standing still and low mpg 2002 yaris andqe DIY / Maintenance / Service 5 09-15-2012 03:32 PM
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
Mabey I Should Go for Low MPG Record? doublewam Fuel Economy Forum 14 07-05-2009 02:59 PM
Why is my new 09 Yaris MPG is so low soup1207 Fuel Economy Forum 34 06-12-2009 03:45 PM
