![]() Drives: Yaris Join Date: Jan 2013
Hi guys,
I just bought this 2008 Yaris. Had a full tank of gas from the dealer. I set the trip recorder to 0 when i left dealer. I lost the first bar on the gas gauge when I had only driven 37 KM. I searched other posts on this forum. Many ppl posted they drive about 70 to 100 miles, which is 112 KM to 160 KM, for the first bar. Should I send this car to dealer to check it right away? What could be the problem? Thanks a lot. |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
I was getting about 95 km on the first bar on my 2007 Yaris in the summer time .. but in the winter time it is much lower than that. But you being from Vancouver .. I wouldn't think that you would see as much as a drop as you guys really don't have the same winter problems as we see in Alberta. But 37 km does seem a little low to me.
![]() ![]() ![]() ![]() Drives: 3-door hatch Join Date: Oct 2010
First of all, are you sure the tank was full? Did you see them fill the tank or did the dealer just point to the fuel gauge and say the tank is full ("See? all the bars are lit!")? The first bar will stay lit even after a few customers' test drives; the tank may have been down a gallon by the time you took ownership. Refill the tank and try it then go to the dealer.
Oh, I get about 70 miles on the first bar driving normally, cruise control set at 70MPH. |
![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
I'll mention it anyway, make sure you are in "D" and not "3"
Fill the tank to the CLICK of the gas pump.
Drive 250km. Fill it again to the CLICK. Do the math. THATS your mpg km/l.
^lol, hey Bronsin that's my usual stock post on these mpg threads. Only I would suggest they drive it all at once.
cheers. |
Thank you guys so much. I think I was driving it in 3 not D lol, dumb of me, didnt pay attention. But i am so thankful for u guys helping me with all these useful info. I will test the fuel efficiency again.
^Not uncommon, welcome, enjoy your car.
cheers. |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
this winter i've only been getting 79-94 for the first bar, summer i usually get 89-110 & low 120s when i'm hypermiling
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
the fuel gauge in my 08 read incorrectly, it dropped the gauge fast. i would hit the last bar at around 270 miles, even if i was getting 46mpg lol
#11 | |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
Also check the tire pressure. When I picked mine up the pressure was only 27psi. (perhaps to soften the ride for test drives) The warning light does not trigger until the pressure is 25psi. After the first week of driving I checked the tires and increased all 4 to full 32psi pressure.
![]() ![]() Drives: red Liftback Join Date: Aug 2007
The 'first' click on the gas pump is not necessarily the same on all pumps. It is there to automatically shutoff the fill. I have had different pumps auto-shutoff at different fill levels. To be sure that I have completely filled the tank...I very carefully and gently hold down the trigger until I can see gas at the neck. Some stations and states will charge you a nasty cleanup fee if you trickle even a drop of gas on the pavement.
![]() ![]() ![]() Drives: '08 Yaris LB Join Date: Jan 2012
I usually get about 90-160 km on the first bar! So, it varies big time.
Obviously the tank wasnt completely full but was full enough to get 37km before the first bar disappeared. tell us how many kms you get when you fill it up for the first time..
Have Yaris will travel.. |
play every day
Guessing at gauge bars and clicking gas nozzles just doesn't cut it. If you want to accurately measure your gas mileage, simply log your distance travelled off the odometer, and how much gas you buy off the pump indicator every time you stop at a station.
Then add up a few of them (not just one) and divide the combined distance by the total amount of gas and then you will know exactly what mileage you are averaging. Anything less is just guessing...
play every day
| Engine fan on when standing still and low mpg 2002 yaris | andqe | DIY / Maintenance / Service | 5 | 09-15-2012 03:32 PM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| Mabey I Should Go for Low MPG Record? | doublewam | Fuel Economy Forum | 14 | 07-05-2009 02:59 PM |
| Why is my new 09 Yaris MPG is so low | soup1207 | Fuel Economy Forum | 34 | 06-12-2009 03:45 PM |
