Old 01-21-2013, 12:36 AM   #21
Absolutely Red 12
Asshole
Absolutely Red 12's Avatar
Drives: 2012 and 2013!
Originally Posted by peckerhead View Post
I can tell my valve adjustment needs to be set, because I can hear kind of a funky idle after I get it hot.
I'm an auto tech, and I've looked into this a little bit. Looks like there are something like 50 different length lifters available from Toyota, and the only way to figure out what you need it to measure your clearances, determine the change to be made, pull the cams, and measuring your existing lifters. The lifters are $25 each from the dealer, and they get $500 to do the job if they need to replace one only.
Have you considered a bad VVT solenoid?
Check your clearances first, at the cost of a valve cover gasket,
You might be surprised.
There are 35 not 50, and they run $12 a piece not $25.
Cheapest DD I could find!!
Absolutely Red 12 is offline   Reply With Quote
VALVE ADJUSTMENT INTERVAL jemmah DIY / Maintenance / Service 7 10-12-2016 10:13 AM
Valve Noise barryware DIY / Maintenance / Service 25 02-13-2013 02:39 PM
Valve lifter Problem !!! Patocine DIY / Maintenance / Service 6 05-08-2012 11:09 AM
Adjustment to the upper shock mounting point? Goose Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-07-2010 03:41 PM
