Old 08-11-2011, 10:46 PM   #1
Betrthanren
Drives: 07 Toyota Yaris
Question Coolant Light
I just purchased a 2007 Yaris Hatchback 39k and I noticed that when I start the car in the morning the "Green" Coolant light will remain lit until I drive it a little bit. I checked the fluid and it was between Full and Low. I filled it with radiator fluid to the Full line and it still continues to do this. Is this normal? I didn't notice it while test driving the car and it only does it in the morning...if I use it throughout the day it doesn't light up.
Thanks in advance for any help you may be able to provide!
Betrthanren is offline   Reply With Quote
Old 08-11-2011, 10:52 PM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Yes, it's quite normal. It's not a Low level light, purely related to temperature. It just means the engine is still cold. Red is bad of course but Green just means that the engine is still cold and needs to warm up. Drive it cautiously until the light goes off and you 'll be fine.
---Reason is we don't have an actual coolant temp guage.
Old 08-11-2011, 10:59 PM   #3
Betrthanren
Thanks for the quick response!
I felt that was the case but wanted to be sure!
Thanks!
Old 08-11-2011, 11:06 PM   #4
rningonfumes
It's alright! Welcome! If you take a quick look at the FAQ thread, you'll read some other topics many others might have been curious about.
Old 08-11-2011, 11:12 PM   #5
Betrthanren
Doing that now! Amazing site!
After learning about the DIY Cruise Control...I'll be doing that this weekend!
Old 08-11-2011, 11:41 PM   #6
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I have heard also that if you have an auto-trans, you can't get into OD until after the light goes off. I have a manual so I can't say for sure. I think it goes off somewhere around 135-140 degrees. I have an ultragauge that shows temp.
Old 08-12-2011, 07:34 AM   #7
BLH
Drives: 2007 Yaris Sedan
Yes my 2007 Automatic Transmission. Will not go into 4th until the Green LED goes out. My Scanguage shows about 130 degrees F water temperature when it goes out.
The shift points are also different until the transmission warms up.
BLH is offline   Reply With Quote
Old 08-13-2011, 11:04 PM   #8
auxmike
auxmike's Avatar
+1 about the A/T. It's real annoying especially in the winter!
Old 01-21-2013, 12:11 PM   #9
jaime1029
Drives: 2008 toyota yaris sedan
This makes me feel much better i had the same issue the day after I bought the car i was terrified i bought a lemon i have been searching to find anwsers!!
I love my yaris thanks!!
jaime1029 is offline   Reply With Quote
07 yaris, coolant, coolant fluid, coolant light
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 02:50 AM
Low engine coolant temperature indicator light -> stays on for 5 minutes... normal ? zimso General Yaris / Vitz Discussion 3 10-19-2010 08:17 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 04:41 AM
Coolant Light lifthard1 DIY / Maintenance / Service 6 07-24-2007 09:40 PM
Coolant Light Cathy DIY / Maintenance / Service 15 09-04-2006 01:28 AM
