'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
Get the Assenmacher toy-640. <<<I highly recommend it. It should be right around $20 USD. It works for both the plastic and aluminum toyota cartridge housings. you need a 24mm socket/wrench on the end of it, but it does the job. It's aluminum, but quality made.
2 things, once the cartridge housing has mated fully with the engine side, stop tightening. it doesn't need to be super tight, just flushed and maybe tapped once. check with CTScott for the appropriate torque specification if you wish. Second thing, remember to remove the tool once you finish using it, it blends into the engine being dull grey aluminum and all lol. Many a lube tech at my job has had to purchase more than one of these tools.
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
