Old 05-13-2013, 10:44 AM   #37
kou
Drives: 08 lb
Be careful driving like that in boost. Detonation is a killer.
Old 05-13-2013, 11:29 AM   #38
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
I could have sworn there was a thread that did some investigation with the 06-08 ecu will throw that code when running the FIC. That person used a 09-11 ecu and it fixed the problem. I can't remeber where I read that
-Derrick-
Old 05-13-2013, 01:27 PM   #39
kou
Drives: 08 lb
That thread is on MicroImage the op has not been on to let us know if it worked.
He has an 07hb and having issues with the cps code so he bought an 08+ ECU to see if that would fix it. There are a lot of cases of this issue with earlier scion models.
Old 05-13-2013, 05:59 PM   #40
TOLMACH
Drives: soarer
Originally Posted by yariSB86 View Post
So after being on duty all weekend, I drove home with the FIC bypass harness connected. The car ran like stock even in boost. Wasn't lean or rich at WOT.
interesting boost present but still not lean?
Old 05-13-2013, 07:13 PM   #41
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Yes, boost present and not lean. was running slightly rich actually, around mid ~13s
@kou - I was only seeing that code, p0135 i believe, while the fic was connected.
The only code ive seen since it has been bypassed is p0172 (system too RICH). And that only came up when i was boosting up to hwy speeds from 2nd-4th gears.
_______________________________________________
yariSB86 is offline   Reply With Quote
Old 05-14-2013, 05:38 PM   #42
kou
Drives: 08 lb
Some more info, your MAF clamp should be set at 4.95v I learnt that this is why I was leaning out up top in every gear I had it set at 4.1v which was what I was maxing out at when NA wot at the top of 5th gear.
Old 05-14-2013, 07:19 PM   #43
That is lean if you're in boost.
Old 05-14-2013, 08:10 PM   #44
kou
Drives: 08 lb
^+1
Old 05-15-2013, 06:52 PM   #45
yariSB86
yariSB86's Avatar
So I tried adjusting the injector size. First changed the numbers, new: 245 old: 190. That threw the fuel map off A LOT. To where the car stalled immediately.
I calculated a 25% reduction from the new:1000 and old: 1000 default. I entered 750 for new, and 695 for old. That ran ok until i revd it up and let it fall. It stalled.
So i reverted back to the original tune you gave me Kou. I went into the ignition map and changed where the car idles from 0 to -3. I revd it up again and it didnt fall. I won't know for sure how it runs seeing how im on duty until friday.
I'll be sure to let you guys know how my drive home goes.
Old 05-15-2013, 07:33 PM   #46
kou
Drives: 08 lb
Good look set your maf clamp to 4.95. I have revised my tune a few times now to get it where it needs to be. I am waiting on a friend so I can do a real street tune, its hard to drive and tune at the same time so I have to pull over change something get back on the road. I am cleaning up the top of my fuel map so its smoother.
Old 05-15-2013, 07:36 PM   #47
kou
Drives: 08 lb
There are a few different 1zz injectors if you know the part # look on http://witchhunter.com/injectordata1.php it should have them and the cc's
Old 05-16-2013, 04:51 PM   #48
yariSB86
yariSB86's Avatar
Nice find with the injector site. Thanks kou!
Old 05-17-2013, 08:53 AM   #49
yariSB86
yariSB86's Avatar
Would this be the correct replacement of my 2007 ecu?
2008 yaris ecu on ebay
Old 05-17-2013, 09:38 AM   #50
kou
Drives: 08 lb
I am not sure maybe you should ask ctscott. I am still waiting to see if that is a fix as someone is trying it an another forum but the have not been on the site in a while. Some have tried a variable resister on the crank wires to adjust until the crank code stops coming up,that fix would be cheaper but will take two people one to adjust and one to drive.
Old 05-17-2013, 08:17 PM   #51
yariSB86
yariSB86's Avatar
So nothing has been confirmed what causes the 07 ECU to throw the cps cel with the fic?
Old 08-14-2015, 08:07 PM   #52
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Bumping for reference.
Old 09-01-2015, 08:33 AM   #53
Bluevitz-rs
Did anyone ever build a MAF map like in the instructional videos?
I'm having an issue where it seem to go pig rich while transitioning into open loop. But if I run all zero maps it's fine.
Old 09-04-2015, 08:12 AM   #54
kou
Drives: 08 lb
I have set up maf map for a maf clamp. Didn't need to use it until I turned up the boost past 12psi and that was only to keep a cel away. If you have no cel piping up I wouldn't use it.
AEM FIC fight for turbo!!! thatbryanguy Forced Induction Forum 135 08-14-2015 08:22 PM
FS: AEM FIC + Wiring Harness Boomslang djgab101 Items for Sale by private party 18 12-06-2013 03:36 AM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 10:42 AM
AEM FIC tuning experience thatbryanguy Performance Modifications 0 09-03-2012 01:29 PM
AEM FIC Tuning Scubaru Steve Forced Induction Forum 37 03-06-2011 11:16 PM
