#19 |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
It really isn't a penalty .. just a fact of how insurance works. Drivers that drive more are more likely to get into accidents and thus they SHOULD pay higher insurance rates than those drivers that seldom drive.
#20 | |
I was listening to a radio show sometime this Spring. A man calls in. He tells the host that a good friend of his bought some 'survivalist' books on his Kindle. Later the good friend got hassled quite a bit (because of these book purchases) when his security clearance was up for renewal. 'Lumping' by driving record sort of already exists. If your driving record all of a sudden gets really bad, you may get put into a separate assigned risk company that has the same parent company...and of course you will pay more with the assigned risk company. People definitely have different views re privacy and a right to privacy. I was just reading a bit about the U.S. constitutional right to privacy on one of the stanford.edu websites. The line I found to be the most sage essentially stated that which personal decisions have been protected by the privacy right has varied depending upon the makeup of the court (the Supreme Court of the United States). We saw that with the decision this week in the DNA case with Scalia and the ladies (an unusual subset) in the minority and feeling as I do. I pay about $500 per year for (specifically) my auto policy, so my savings with your path would be barely over half your savings. |
#21 |
I'm okay with the reporting of the mileage thing because I understand an entity that makes the assumption that people are going to lie. I remember when 'your' agent asked you how many miles you drove a year -- just when starting with a new agent. Then the subject was never broached again. Obviously, as the world changed, that was no longer good enough. What I feel 'pushes over the line' are 2 things I can think of right away 1. 'you need to have a front plate on because the cops need to see the front plates of criminals' (a dubious perceived requirement IMO) -- even if I am not a criminal, I'm getting lumped in with them (IMO) and 2. The SCOTUS decision this week re taking a DNA sample of someone ACCUSED of a serious felony to see if the DNA matches any unsolved cases. I'm fine with this if they do it to someone who has just been CONVICTED, but not merely ACCUSED.
#22 |
I got nothing to hide either but.....
I have been driving for many decades and never had an accident . I started driving defensibly from square one before it was even called "defensive driving" . To me it was always the only way to drive. The only time I ever filled any sort of claim is when my car was hit when legally parked. However, I often l go for WOT and other things an insurance company would raise my rates for. I never put my car ( or any other car) in danger no matter what I do It's like like this.... you can not say a person will most likely die (or not) if he jumps out of a airplane if you have no idea if he is an experience skydiver and has a parachute or, if he is just an idiot jumping out of a plane sans a parachute. These insurance OBD monitors can not detect any sort of "parachute", experience, circumstances, etc and often reward bad bad drivers while penalizing good ones. As the saying goes, "a little knowledge can be a dangerous thing". Last edited by RedRide; 06-05-2013 at 12:18 PM. |
#23 | |||
only issue, if you can call it an issue is that unless you have an dlc port splitter you cannot run more than 1 obd device, i have a blitz r-vit (a fancy scanguage) and i had to get a splitter cable to run both at the same time. battery power will never run out, the snapshot device used a very small amout of power, in sleep mode with the car off current draw was only .06 mA. Quote:
i was already with progressive because they were the lowest rate for identical coverage, i have been with progressive for 8 years and all the cars and house are all with progressive, every year i call them and hassel them about the rate and ususally it gets dropped a little. Quote:
if you dont put a lot of miles on your car or you dont drive at night often then its for you weather you drive fast or not, i am a very offensive driver, i do not drive slow and i do drive a "performance" yaris. wide sticky tires and lots of suspension upgrades helped me because i dont brake that often or slow down for corners, stop signs and red lights need to be anticipated so you dont brake to hard but since they dont take speed into consideration you can still drive as fast as you want. i did however take the snapshot out of my car when i go autox due to the lots of hard braking |
#24 | |
Asshole
Drives: 2012 and 2013! Join Date: Aug 2012
Wouldnt you want to make sure the odometer wasnt tampered with when you buy a used car?
Cheapest DD I could find!! |
#25 | |
Asshole
#26 | |
Asshole
Drivers that drive more, have more experience!! My last accident was 1976, Im still being rated by my mileage, and zip code. Not my driving record!!. Can they tell I just drove 800 miles through desert highways, which I just did!
#27 |
2ZR swap. DO IT! Ask how!
I'd like to get one of these and take it to an AutoX event. See what kind of rates they quote me with. =)
#28 |
#29 | |
#30 | |
#31 | |
I've only had 2 cars that either I or another family member didn't buy new. One was my first car that I bought with my own money. My dad was working for a Ford dealer at the time and the General Manager gave it to me for the amount the trade amount (so the dealer didn't make any money nor lose any money), which was WAY under wholesale book. My dad approached the GM after the car had already been evaluated and taken in from the customer. The other car I had that was used was a Mitsubishi Galant VR-4 AWD Manual Transmission (very hard to find when I bought one). I'd always wanted one. It had a salvage title and had been rebuilt by a mechanic who buys such (salvage title and the like) and rebuilds them. I knew I had little way of knowing how many miles were on it, but it was so inexpensive I felt it was worth it even if it lasted 20k miles (it was a second car). I drove it through California, Nevada, Idaho, Wyoming, Montana (over the Going To The Sun Highway), Idaho again, Washington, Idaho again, Wahington again, Oregon, and then California again. On a later trip, I was driving on CA 58 near the intersection with 395 (on my way to Las Vegas for New Year's Eve) and with about (ironically) 20k miles since purchase it threw a rod and I let the towing yard have it. Those 20k miles were definitely worth what I spent. I don't know if I'll ever buy a used car again (....only, I think, if I found an 'Idahotomlike' RAV 4), but yes I'd like to be able to rely on the mileage stated re a used car. I'd only believe it if I knew how any state tracking would specifically ebsure that and believed in the integrity of that procedure. The only thing is, applying your question to Texas, I would think that would only be truly knowable for cars that had never been registered outside of Texas, or (if they had) had only been registered in other states that have the same requirements Texas does. Has California instituted any policies recently that help consumers re odometer tampering? |
#32 |
...and the computer system at at least one insurance company (mine) is programmed to set the rate to your mailing address. My house and my UPS Store PMB box are in different zip codes. When I got my initial quote (which was the lowest I found), it was based on my house address. I hadn't given the agent the other address yet (and the other address wasn't in any database for me yet---other than the UPS Store). After noting the advantageous terms, I signed up for the policy and gave my UPS Sore PMB address. I soon got the paperwork there (different zip) and the rate was about 10% less. I talked to my new agent and he said that's just the way their system applies it, that even if they were able to change it, it would 'correct back' to what I had in front of me. He said, 'count your blessings'. This probably gives them an edge when I do comparisons each year.
| "5 Driving Myths That Cost You Money" | PETERPOOP | Fuel Economy Forum | 10 | 05-24-2011 10:20 PM |
