![]() ![]() ![]() Drives: 2010 Yaris 3 door, manual tran Join Date: Jul 2013
When to shift
Hello Everone,
I'm bringing up a topic already discussed in this post, http://www.yarisworld.com/forums/showthread.php?t=5979. It says to never let the RPMs rise over 2k or 2.2 for merging. As some of you know I'm new to yaris and I'm new to the manual world. So my shifting is really crappy,and not smooth. I usually shift at 2.5k because I kind of let the RPMs drop trying to find the catch point between shifts. Should I try the 2k shifting? |
If you want to save fuel, sure. If you want to get where you're going, shift based on the current driving conditions, terrain and when you feel like it.
I used to shift at 2k for the fuel savings but it tends to put you around 1200rpms at the next gear. that is alright as long as you don't have to accelerate quickly.
The yaris also reacts well to shifting around 5500rpms and it is a lot more fun... |
i shift at 4000 all day everyday...
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
when the needle starts bouncing off the redline
Fuel cutoff shifts FTW |
Mr. 155 and climbing
When I was in ECO driving mentality I would do the whole shifting around 2k-2200, but really I find the best spot for smooth shifting being at the following which you might want to try until you are more comfortable:
4k, 5k, 5800 shifting I have noticed between 2500-4k seems to be more blunt. DISCLAIMER: I am not responsible for any information I have provided. I am just relying on my 6 year experience with the C50.
![]() ![]() Drives: Want a yaris Join Date: May 2012
Just keep driving and do what feels right for you. You will get the feel for when to shift depending on power needs and the situation. Everyone drives a manual differently. There isn't really a set way you need to shift. Enjoy the drive!!!
Back in the day, there used to be a little light (arrow pointing up) to tell you when to shift. I found out quickly that if you floor it, the light goes off...
I don't think shifting at 2000 rpm gives the best mileage, and it usually bogs the motor if you're trying to accelerate. At least 3000 rpm will make the car a lot happier.
I used to shift at 2k rpm when ever I was able to creep up in speed. But since getting heavier wheels, I'm now shifting between 2.5k and 3k.
2ZR swap. DO IT! Ask how!
I've made some spreadsheets and charts to figure out speed vs rpm (before I had a tach). Here's a post that has the stock gears vs their redline shift speeds: http://www.yarisworld.com/forums/sho...53&postcount=9
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
New manual transmission corvettes lock out gears 2 and 3 when in eco mode. This forces you to go from first to fourth.
Some GM engineer thinks it is best to do most of your acceleration in first and then maintain speed with the higher gears. FYI...after the fourth gear shift has been done, you are allowed to downshift to second or third. |
#14 |
^ That's the goofiest thing ever. Who would want to hypermile a Corvette?
#15 |
#16 | |
Fuelly lists my last 10 fill-up average at 39.7mpg, and that's with consistent 3k shifts!
#17 |
Yup, each car is different. When I drove BailOut's LB, he told me to drive 55 mph in it since that's where he got the best mpg. Then I applied it to my car for almost a year, and got fed up with the not so great mpg I was getting. So I started experimenting and found that going 60-75 mph (just keeping the throttle at 24%) produced the best mpg for my car. hahaha. Last tank for me was 39.4 mpg with mostly city driving and I kid you not, 95% of all stop lights I encountered turning red on me last second. Also, with having to rotate 43.5 lbs in each corner. HAHA
#18 | |
| Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! | TWM Performance | TWM Performance | 13 | 09-29-2009 10:55 AM |
| TWM Performance weighted shift knobs on sale! | TWM Performance | TWM Performance | 5 | 06-30-2009 09:58 AM |
| New shift knobs available from TWM Performance! | TWM Performance | TWM Performance | 3 | 06-25-2009 04:24 PM |
| October sale on TWM Performance shift knobs! | TWM Performance | TWM Performance | 1 | 10-31-2008 05:01 PM |
