![]() Drives: Toyota Yaris 2007 Join Date: Nov 2012
So I finally was able to reach Autozone, get the codes checked and three different codes popped up. But as I was leaving autozone, the car was fine again, except that the check light was still there (but I reset that when I came home) and it didn't come on again.
A night before this happened, it poured down here in Florida and I really did go in some puddles, so my guess is that some water went in some sensor or somewhere which made it act all up. Hopefully it shouldn't happen again, but if it does, then I'll most probably be changing a few sensors that came in the code readings. Thanks for the help guys, but this is not just it. A few months back I installed a new rear wheel bearing that I got off ebay as my old one made some noise. So everything was alright until the ABS light came on. Instead of taking it off and shipping it back to the seller, I thought that I'd just change its ABS/Speed sensor with a new one or the old one of my previous bearing. Now my only question is that how do I take it off? (the ABS/speed sensor) I'm thinking of putting it in a vise and removing it like that. If anyone else has done it, then do let me know, thanks. |
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| Toyota Recalls | auxmike | General Yaris / Vitz Discussion | 535 | 02-25-2021 06:13 PM |
| rough idle.... | dindy | Third Gen Yaris General Discussion | 5 | 06-12-2013 12:48 PM |
| 3rd gen 1zz tb swap | mr_miles | DIY / Maintenance / Service | 26 | 05-01-2013 08:20 AM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
