![]() Drives: 2009 Toyota Yaris Join Date: Feb 2012
I think I just blew my ECU while putting in an aftermarket radio
Hello all,
While attempting to install a new head unit into an North American 09 LB, I think I may have blown the/an ECU. Here are some of the variables I'm working with while trying to diagnose the exact problem: -Everything works but the car will not start, starter clicks very rapidly like no other dead battery I've encountered. Think I will have it tested anyway. I also jumped it. -The head unit in question is a Pioneer AVH-X8500BHS. The harness was professionally soldered and shrink wrapped by a friend, with one catch. I ordered a kit on amazon used to bypass the requirement of the parking brake in order to watch video while moving (i just wanted the option, i would not drive while watching a movie). I lost the instructions, so we had to guess where 2 of the 3 wires went. Obviously black to ground, but we guessed blue to blue, light green to dark green. I think this is where we may have shorted something out. -I checked "most" fuses, but was in a rush and feel I need to check again. EFI fuses were good. -What I believe is the nail in the coffin is when I tried to scan for error codes, my scanner only states linking error. Perhaps it may be a burned out wire, but shouldn't the fuses prevent a wire from burning? I smelled no burning. If it is the ECU, where exactly does that leave me? I know they are cheap but will need to have some sort of dealer work done on them. -Thank god I still have my MR2 to get me places. Thank you all for any input. |
#2 | |
The four fuses your might have popped are MET, ECU-IG, and ACC (all under the bottom of the dash) and DOME (in the under hood fuse panel).
DOME and ECU-IG will prevent the ECM from powering up.
Turned out the battery was much more dead than I thought. Never seen one drain so fast. Also that ECU code really put me in a tizzy. Mistake of a mere mortal. At least I've learned a partially dead battery can mimic a bad ecu.
/thread |
| Tags |
| ecu, short, wiring |
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| No AM radio signal on two aftermarket HUs? | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 10-08-2014 04:15 AM |
| ATL, I want to trade my Upgraded built in radio... | matthewallanstill | Southeast | 2 | 03-28-2009 06:29 PM |
| Factory wire harness or plastic aftermarket piece for aftermarket radio????? | Yarisguy13 | Great Lakes | 1 | 09-17-2007 10:14 AM |
| Toyota AUX plug w/ aftermarket radio? | eight_heads | In Car Entertainment + Electronics (audio / video / alarm) | 20 | 09-07-2007 02:41 AM |
