#2557 |
Loll @4 post.
You guys just need to stop being social ! Bwahahaha!
![]() ![]() Audio is under Construction Kenwood KDC-X794 Hifonics Zeus ZXI6.5C 6.5-Inch 2-Way Component Speaker System - AUTOTEK ATX65CX 6.5-Inch Hifonics BXi 1210D - Crunch PowerZone P1400.4 (2)12 inch Kicker CVR's - 0 gauge from battery to Distribution block - 4 Gauge Power/Grounds to amps - Duralast Yellow Top - Big 3 |
#2558 | |
similar to this setup: D.
. CLA 250, 4MATIC |
#2559 |
. CLA 250, 4MATIC |
#2560 |
You're lucky D. You have seasons. Down here in South Tx we have Summer then around Nov. We have Summer/Winter. Basically you leave in the a.m bundled and use the a/c on the way home.
#2561 |
![]() ![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
That is one gorgeous area - we only have winter/summer here in Vegas as well. It snows here once every five or ten years, but if we want snow, we head to Mt charleston or somewhere in Cali.
#2562 |
Roadrunner Jr.
I don't know of an inexpensive or plug and play way to convert the P-99 to that setup.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
#2563 | |
![]() Most of the time YW members PM me with direct questions, I do have in other forums my build without the everyday log. Some are public some are private, but YarisWorld always gets the best honest, useful information. D.
. CLA 250, 4MATIC |
#2564 |
Roadrunner Jr.
D,
Heads up, if you're going to compete IASCA next year, make it happen. I attended the finals again this year...as a spectator this time. It was good to see everyone on the West Coast team with some new additions. The bottom line is, the cars haven't become "better". There's only so much you can do to certain platforms. I'm here to tell you, the potential of the Yaris hasn't been fully realized yet. What you need to do is not get your P99 to die the night before finals and get better than 4th in the world in Pro/Am. Then you top me...I know you can do it...I want you to do it mang...
#2565 | |
How did the Bit 1 worked for you? D.
. CLA 250, 4MATIC |
#2566 | |
![]() D.
. CLA 250, 4MATIC |
#2567 |
Roadrunner Jr.
If one had more space to listen, like a room, the height wouldn't be so much of a factor.
The bit one was very easy to learn and operate. Audison is making it better and better with all the add on values like Bit Tune. I wouldn't hesitate to use it again...DO NOT modify the piece!!! I cannot stress this enough. There is no reason to modify it. That modification of the Bit One cost me a world championship and I'll never forgive the team for not informing me of the near 100% failure rate of the modded pieces...I found that out the hard way. Just one of the several reasons I'm not with Team Hybrids anymore. Good ethics are completely foreign to the team leadership and brand ownership.
#2568 |
. CLA 250, 4MATIC |
#2569 |
Roadrunner Jr.
Why Derick...What is that?
*feigning suprise*
#2570 |
That's a CLS (belongs to one of the owners of the company that I work for)
that car is huge outside but smaller than the Yaris in the inside at least the Pilots seat. lol no surprises for now, just a picture with leaves and a dream car. D.
. CLA 250, 4MATIC |
#2571 |
I got some kids-Halloween music 4 my kids, thought about running the tracks in the Yaris!
AWESOME! lots of special effects that make the ride such an experience! ![]() Some car-audio enthusiasts from Massachusetts are planning to have another meet. D.
. CLA 250, 4MATIC |
#2572 |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
I was curious as to why not running a huge patch of dynamat or imitation dynamat across areas (covering all but tubes in doors, etc.) ? Instead you had small patches here and there...Curious ?
On another note, (I want to dynamat know my doors for obvious reasons), but before I did, I wanted to let you (and others) that I put two cans of 3M undercoating on my underside (floor pans/ metal parts of wheel wells) with dramatic noise deadening improvement. For an even better coat, let dry and hit with two more cans. (I am just going with 2 for now), until I get my speakers and dynamat and see what that does for it, sound deadening wise.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
#2573 | |
If minimizing road noise is your goal, it's better to use a thick material what I call CLD Tiles (to control reverberations) only require 25-30% of coverage from a flat metal area + a Layer of CCFoam and a Layer of MLV. (that is good to block road noise) If your goal is controlling rattles from big BASS Subwoofers, then complete layers of Mat are the way to go, but if you overdue you'll find your self inside a big box like a guitar box where YES you block the road noise and control rattles but the reverberation will create other noises, just like inside a guitar. I did a combination of both where in some areas I'm aiming at blocking noise (road noise) and some other areas to prevent rattles from the BASS. Take in mind that a system of CLD Tiles (only covering 30% of the metal flat surface) + CCFaom + MLV is about the same as 3 or 4 layers of MAT when your goal is Blocking Road Noise. Here is a good source of information regarding Deadening just follow the LINK D.
. CLA 250, 4MATIC |
#2574 |
In other words when I put small patches means that I'm covering 30% of a flat metal area to control reverberations, as part of a system to block road noise.
D.
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
