Old 10-30-2013, 03:25 PM   #11
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I was curious as to why not running a huge patch of dynamat or imitation dynamat across areas (covering all but tubes in doors, etc.) ? Instead you had small patches here and there...Curious ?
On another note, (I want to dynamat know my doors for obvious reasons), but before I did, I wanted to let you (and others) that I put two cans of 3M undercoating on my underside (floor pans/ metal parts of wheel wells) with dramatic noise deadening improvement. For an even better coat, let dry and hit with two more cans. (I am just going with 2 for now), until I get my speakers and dynamat and see what that does for it, sound deadening wise.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires
TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
JimKellyfan is offline   Reply With Quote
