Old 12-13-2013, 10:30 AM   #19
The 62mm studs, no I could not get in. I'm borrowing the following pic which shows, like I previously mentioned the possibility of having enough room by removing a shoe.
I found an extra extended stud that I had purchased when I discovered the Ichiba ones were too long. Despite what I had mentioned a few posts back, I ended up getting OE + 5mm (50mm). These I was able to wiggle in, and still had ample thread for the 10mm spacer. That said, you should be fine with a 55mm stud in the back. Any longer than that and I'd say you'd be in the same boat I was.
This is becoming an horribly long, and potentially confusing discussion on stud length. Hopefully some others will chime in eventually as plenty of 10mm+ wheel spacers have been installed in this community.
wheel spacers diy
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
