Old 12-13-2013, 04:30 PM   #30
Jason@SportsCar
Originally Posted by Lars View Post
So you're telling me that if I unscrew those four bolts that can be seen from the those big holes on the plate where the studs are (I'm guessing that's what you call the hub?) I can just take the hub away from the "wheel" and replace the studs? That's surely good info if I can't make the stud fit somehow.
Just measured the stud. 62 mm, so not very different from the 60 predicted!
Exactly, makes it much easier. *If you have ABS you will need to unplug the wire on the back.
wheel spacers diy
installing Penguin Garage rear hub spacers! Tamago DIY / Maintenance / Service 101 05-21-2011 12:29 PM
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
Installed 10mm PG spacers on a 15x7 +25 wheel kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-27-2009 07:10 PM
Steering Wheel Spacers? BassAssassin Cosmetic Modifications (Exterior/Interior) 0 08-12-2009 12:52 PM
