Old 10-31-2012, 01:22 AM   #1
1nzmr2
Drives: 1nz MR2
How to raise RPM limit
Here is a link to a video I made on one possible way to raise your RPM limit: https://www.youtube.com/watch?v=Xyec...feature=relmfu
You can also search Youtube for "Denso raise RPM"
Please check out my other vids too and comment below them and give a thumbs up if you like them.
Thanks, John
1nzmr2 is offline   Reply With Quote
Old 10-31-2012, 01:37 AM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Thanks for sharing, John! This looks like an interesting mod for sure.
Just a few questions:
1. It seems that you used a 1ZZ-FE ECU. Do you know if 1NZ ECUs also have 2 crystals?
2. Does this procedure affect anything other than the RPM limit?
3. Do you know where to get that magnum regulator?
Old 10-31-2012, 10:38 AM   #3
1nzmr2
Drives: 1nz MR2
Glad you enjoyed the video!
1. I don't know how many crystals are inside the 1nz ECU. An automatic transmission ECU may be different from a manual transmission ECU as well.
2. When I raised the clock speed beyond a certain point on the 1nz MR2 the idle became rough and the car would not restart. Also at that point the door locks on the MR2 would cycle after I pulled the key from the ignition. I reduced the clock speed a little bit from that point and all was well.
3. I purchased the unit directly from the Magnum Tuning website.
Old 10-31-2012, 07:17 PM   #4
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
What is the maximum safe RPM limit for the 1nz-fe? I vaguely remember reading that the yaris RPM limit is less than what should be safe, but I can't remember the reason.
My guess is you'd need different cams to take advantage of the limit change? Also, is there any ecu's from other cars that you could swap into the yaris? I know we used to do this back when I messed with obd1 Hondas, I hadn't thought to try something like this in the yaris but it makes sense.
4/20 NEVER FORGET is offline   Reply With Quote
Old 11-01-2012, 12:51 AM   #5
I think Jason ran up to 7000 on stock everything. Stock is 6250. I am at 7300 with upgraded springs only. Our new spring kit would let me go to 8000.
My car n/a though, even with bolt-on mods, stopped making power about 5800 (thus the stock rev limit, most likely). No reason to rev higher unless a dyno shows that you're making power up there and would benefit.
Old 11-01-2012, 12:09 PM   #6
Jason@SportsCar
Our Runoffs race setup is 7300rpm with stock springs and JUN cams - previously ran 7300rpm with the stock cams as well - most of the year we turn it down to 7100rpm.
Might try some MI spring this next season and see if the car will make power past 7300rpm. The dyno indicates there is more up there, we just have not wanted to push the valve train or crank that hard yet. Now that I have a spare engine I am willing to push it a little harder.
Old 11-01-2012, 12:26 PM   #7
Our ECM has both microcontrollers clocked with 16 MHz crystals, but I would consider this a dangerous mod, as everything else timing-wise for the ECM is also based off that frequency.
A much simpler and safer method would be to use the module that I created for allowing us to use metric instrument cluster (and have the speedometer and odometer increment in MPH). The tach feed to the ECM is the same type of pulsed signal as the speed signal, so theoretically the same method would work for fooling the ECM about RPMs. Here's a video of the speedometer device in action:
http://www.youtube.com/watch?v=KkUOgEvTYAY
Old 11-01-2012, 06:59 PM   #8
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
What sensor is used for RPM, if it's the same as the crank then you can't mess with it or your timming will also be screwed along with injection.
Old 11-01-2012, 07:05 PM   #9
Without modifying the 6,600 RPM constant in the firmware, any modification to the limit will require manual adjustment of the maps via a piggyback.
Old 11-04-2012, 01:44 AM   #10
b20vteg
no show, no go :(
b20vteg's Avatar
Drives: 2012 yaris 3dr hb
exactly.
b20vteg is offline   Reply With Quote
Old 01-31-2014, 11:30 AM   #11
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Bringing this back from the dead, what exactly is the downside of doing this to the ECU?
Old 01-31-2014, 12:06 PM   #12
As I mentioned in post 7, changing the clock frequency could cause a variety of problems, including communication problems between the ECM and the other ECUs, or could cause much more catastrophic issues, like runaway conditions.
Old 01-31-2014, 01:14 PM   #13
7:34pm
Drives: 07 Yaris
Anyone ever checked the balance on the stock crankshaft?
7:34pm is offline   Reply With Quote
Old 01-31-2014, 02:21 PM   #14
RJay
Drives: 2002 Toyota Yaris T-sport
I have a stock 1nz-FE in my european T-sport model and the rev limit is 7500 rpm in 4th and 5th.
Stock.
So that's quite a lot, my bmw racecar runs 7300 max.
1st through 3rd the limiter is at 6500 by the way.
198X BMW E30 modified race car
1975 Ibanez "Les Paul custom"
RJay is offline   Reply With Quote
Old 01-31-2014, 02:37 PM   #15
xnamerxx
0-60 in slow
xnamerxx's Avatar
Can you post a on for the ecu
Old 01-31-2014, 02:41 PM   #16
RJay
a "on" ?
Sorry but I miss your point there.
(I don't even know yet where the ecu is located in the yaris p1, lol. I've only had it for 4 months and it's my road car)
Old 01-31-2014, 03:12 PM   #17
IllusionX
Drives: 07 Yaris Sedan Aero
Originally Posted by RJay View Post
a "on" ?
Your ECU is under the glove box i remember.
Old 01-31-2014, 03:48 PM   #18
RJay
Okay, so what's this "on" xnamerxx is asking for? :) I'll see if I can find it in the weekend.
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 03:10 PM
Vitz 2001 1.0 manual rpm diesel2901 DIY / Maintenance / Service 4 09-23-2011 12:02 AM
Turbocharged Dyno Result cdydjded Forced Induction Forum 24 08-23-2010 10:54 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
