Old 05-13-2014, 12:50 PM   #19
IllusionX
Drives: 07 Yaris Sedan Aero
What does Toyota recommend in your country? I keep reading people using 10W30 in very hot countries.. but you might also want to change oil more frequently, ie at 3k miles instead of 5k miles.
what kind of filters are available in your country? If you can get toyota filters, just go with that.
Old 05-13-2014, 06:10 PM   #20
jcboy
Drives: Sedan 07
1) engine flush is not good, it flushes even the oil films on the pistons/rings.
2) use a multigrade multipurpose oil (for diesel and gas engines), then use it for 1000km (~600 mi) then drain it and use a good oil like mobil 1.
3) never use lower than xxW-40 oil, since your country is a bit warm/hot, oil will thin out a lot if its like xxW-30 or lower (don't worry about the xx since that is cold weather rating). if your oil thins out a lot, oil degredation will likely happen more/faster.
4) toyota nz and zz engines were/are rumored to be prone to sludging, don't use conventional oils for more than 5000km (~3000mi) and FULLY synthetics for more than 10k km (~6000mi).
i would assume this is mostly city driving and since sludging is partly caused by pollution as well as long oil change intervals. if it is dusty where you drive most of the time, be sure to change the air filter every 4th oil change.
HTH :)
Last edited by jcboy; 05-14-2014 at 12:23 PM. Reason: oil filter --> air filter :)
Old 05-13-2014, 11:07 PM   #21
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Nonsense. This is not like flushing your toilet or running 100% solvent in the crankcase. One uses it in small concentration (up to 10%), idling and and for short time only. It just increases oil solvency to take the sludge away.
If engine is badly sludged, pan has to be dropped to inspect oil pickup screen to prevent oil starving.
So yes, one needs to know what one is doing of course.
jack black is offline   Reply With Quote
Old 05-14-2014, 12:36 AM   #22
trunkout
4 years of P90X!
Drives: 09 Yaris Sedan
I use the Fram Extra Guard # PH4967
trunkout is offline   Reply With Quote
Old 05-14-2014, 06:57 AM   #23
CB900F2
Drives: 08 Sedan
Give http://www.auto-rx.com/ a try...
Old 05-14-2014, 06:58 AM   #24
bronsin
bronsin's Avatar
Originally Posted by jack black View Post
Nonsense. This is not like flushing your toilet or .
My dog used to drink out of the toilet after flushing it its probably OK...
Old 05-14-2014, 09:09 AM   #25
Yarisaur
Drives: 07 Yaris
LMAO
Yarisaur is offline   Reply With Quote
Old 05-14-2014, 09:37 AM   #26
IllusionX
be sure to change the oil filter every 4th oil change.
nonsense. You change your oil filter at every oil change! The filter can only hold so much...
Old 05-14-2014, 12:25 PM   #27
jcboy
Drives: Sedan 07
if that's how it's done, (10% at a time), then it should be good. (IMO engine flush fluids here are instructed to be used as if it were oil )
Originally Posted by IllusionX View Post
nonsense. You change your oil filter at every oil change IMHO! The filter can only hold so much...
edited, sorry for the typo that's correct, oil filters every oil change. air filter is what i meant.
Old 05-14-2014, 12:47 PM   #28
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
better filters
I think there are better filters out there. I heard the fram has cardboard end caps.
Also, I only change oil every 10k miles with synthetic and it seems OK, but there is a lot of freeway mixed in with the driving. Also Mobil 1 has a extended version with a 15k service standard.
regards to all, Alan
alanwagen is offline   Reply With Quote
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 10:08 PM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 02:01 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 08:11 PM
