Old 06-10-2014, 09:05 AM   #1
DarkSkyGhost
Newbie
Drives: Yaris 2003 1.0L
UPDATE:
So I bought two Quick Brake QB113-1379X parts, which look almost identical to the original ones and installed them in the original locations - put the pin with a rubber thingy on the lower part of brake caliper support.
Also swapped brake pads around from left to right and vice versa to even out the wear - inside of the right brake disc was rusted out as brake pads weren't biting there.
Brake pedal feel has improved, brake pads start biting almost immediately.
Overall I'm very happy with the results.
Here are some photos of the old pins, you can see that after 170k km they are damaged in a couple of places, no wonder there was some play in caliper movement:
http://imgur.com/a/GZhBs
DarkSkyGhost is offline   Reply With Quote
brake, caliper, front, pins, support
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 09:47 AM
Front Brake Pad Costs imoverthere DIY / Maintenance / Service 0 12-19-2013 01:15 PM
Front caliper brake measurements wildmongoose26 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 11-17-2013 08:18 PM
FL-BNIB OEM toyota front brake pads gray09S-hatch Items for Sale by private party 7 04-19-2012 01:17 PM
Front brake clunk after reversing JonS DIY / Maintenance / Service 6 03-21-2012 12:02 PM
