Old 10-08-2014, 12:37 PM   #37
ucsmfu
Drives: yaris le
Originally Posted by nookandcrannycar View Post
I found a source for OEM power folding mirrors. Awaiting price quote at the moment :) Will keep you guys updated.
ucsmfu is offline   Reply With Quote
Old 10-08-2014, 03:29 PM   #38
You can do the LED turn signal ones without a problem, but for the folding ones you will also need the power mirror switch for the folding mirrors.
Old 10-08-2014, 05:50 PM   #39
jcboy
Drives: Sedan 07
Assuming the 2013 yaris have the same switch as my 2012 sedan, then i can source out the mirror control with retract switch for 1300 pesos here, or around $30. If there were no shipping costs i would say this is a viable option for you guys there.
Otherwise you can probably get from the junkyard as the toyota siennas and rav4s (limited) there have power fold and use the same switch.
Old 10-08-2014, 06:16 PM   #40
With some of the other US Toyotas the switch is slightly different and does not fit into the slot in the dash on the Yaris.
Old 10-08-2014, 07:10 PM   #41
jcboy
Drives: Sedan 07
Oh i see. I guess i was just looking at the connector (what we call pigtail here) when i was doing my research back then. Over here only the Prius and Hiace (as they have lighted switch) have a different switch connector, but every model has the same black switch as your yaris 2006-2011 there has.
Either way, im not sure what the Yaris 2012-up switches are like.
Old 10-08-2014, 09:21 PM   #42
ucsmfu
Drives: yaris le
I had power folding mirrors in my previous 2010 Prius (Canadian model)
The switch and mirrors came from a Toyota Wish. Controller worked ok
Here's what it looked like http://i.imgur.com/8TUzwu7.png
http://i.imgur.com/CSE93Ik.png
Old 10-09-2014, 12:50 AM   #43
ucsmfu
Drives: yaris le
http://www.ebay.com/itm/MIT-TOYOTA-L...item19e2cef089
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
