Old 10-09-2014, 12:49 AM   #1
Ben_
Drives: 2010 Yaris Hatch
I experimented with this recent at the auto x. Used premium fuel as opposed to regular I usually run. I noticed quicker throttle response and the engine ran a bit smoother. Maybe it's all in my head. The more experienced users will know if premium fuel will change the timing the ecm gives
Ben_ is offline   Reply With Quote
Old 10-09-2014, 09:42 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
Originally Posted by albee213 View Post
I read some information about the Yaris engine and I found out some interesting stuff.
The engine specs show 10.5 to 1 compression ratio which would mean it should use premium fuel to prevent early detonation.
This engine can use regular fuel do to improved technology in how the fuel is injected and the shape of the combustion chamber prevents pre-ignition of the fuel while squeezing a little bit more power out of the fuel.
After saying that I still use mid or prem due to the high compression ratio of the engine, to each their own.
Except that is bogus. The computers control the system so much more than 30 years ago. Everything is different and your ideas are just wrong. Toyota recommends 87 and it is a waste of money to run anything else on a near stock engine.
10.5 to 1 is not high compression anymore. There are gas engines that run more easily. Toyota has used this engine in this configuration for at least 20 years, probably longer. It is rock solid with the crappiest gas you can find to put into it.
Higher octane could make the engine run 'smoother' although that in no way equates to making more power or getting better throttle response, especially since the throttle is controlled by a computer.
Colin Chapman disciple
Facts of Higher Fuel Octane Yaris TTE JWRC General Yaris / Vitz Discussion 9 01-29-2007 08:16 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 08:17 PM
What type of octane I should use??? krakkhenz DIY / Maintenance / Service 95 08-23-2006 06:53 PM
What octane fuel is recommended? sroberts General Yaris / Vitz Discussion 4 06-09-2006 09:54 PM
octane at high altitude. chibianh General Yaris / Vitz Discussion 10 05-16-2006 01:47 PM
