![]() ![]() ![]() Join Date: Sep 2014
Cruise control, yaris 2015, 5 speed
I bought this oem parts,And i will tray to install it tomorrow.
![]() I will use your DIY, for 2007 if i remember well. I will update with pictures, this post. I hope this Work well. Any tips, i will be appreciated |
Check out this thread for pictures of how to release the airbag clips on a 3rd gen:
http://www.yarisworld.com/forums/showthread.php?t=37205 For the clutch switch, see my 2nd gen cruise control DIY: http://www.yarisworld.com/forums/showthread.php?t=33750
Thank you ctscott. I will do today around 17 hrs
Out of curiosity, what did you pay for the parts? It also looks like they sold you two separate harnesses and you only need one or the other.
First doubt... No screws taked the Air bags... Only this "wire" with hook.
I paid around $110 usd |
#6 | |
Correct. The 3rd gen has spring clips to mount the airbag. The first thread that I linked above shows them. I could have saved you quite abut on that price.
I found this
Where do the beige and brown wires go (from the white connector)?
Also, check the steering column connector to see if beige and brown wires are present in the black connector, next to the yellow airbag connector.
See the picture please
I connect the batery And puede the switch on, push the the stalk and the image on the panel turn on (green light)
ctscott, thank you for your help, i think this Work.
Ctscott, do you think, i will check anything before use/test it
I did a short drive, around 3 - 4 minutes, to check if the Cluster show any warning . And all ok
#14 |
Very good. As long as you see the cluster light illuminate and don't have the airbag light stay on, you are good to go.
#15 |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
Our 2nd gen MMC steering wheels also have spring clips only too, there are just covers on each side to have access to them.
Too bad i dont think we have cruise control available in our ECUs.
#16 |
i did a drive around 10 kms, and cruise control works.
one doubt, when i drive around 40 kms and try to Set the Cruise, but dont work, but when i go around 65 kms, it work. |
#17 |
The minimum speed for cruise control to "set" is 25 MPH, so that's just about right for the threshold you are seeing.
#18 |
Thank you
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control for manual trans Yaris $150 | kharrar | Items for Sale by private party | 4 | 10-09-2010 12:09 PM |
