![]() Drives: 2013 Toyota Yaris Join Date: Nov 2014
2013 Toyota Yaris headlight problem
I'm having a problem with my front headlights and was hoping someone may have an idea of where to begin to look.
On the front headlights there are little yellow lights that flash when locking/unlocking the car. With the headlights turned on only one of these lights turn on (the passenger side) and the other remains off. The light is functional though as locking/unlocking the car lights up that same exact light correctly on both sides correctly. Does anyone have any idea of where I should begin to look for solving this problem or maybe even the solution to it? The car is a 2013 Toyota Yaris LE edition if it helps. Last edited by Tgawe; 11-05-2014 at 10:11 AM. |
Does your car have factory installed or aftermarket keyless entry?
Yes. Is the The keyfob remote a real Toyota one (or is it a key integrated with the remote). If so, it is OEM, if not it is aftermarket.
#5 | |
Like this: http://ecx.images-amazon.com/images/I/31FVnmdsb0L.jpg |
I think he is talking about the parking lights. Yellow that doubles as a flasher/signal...
#7 | |
EDIT: http://postimg.org/image/6ciueq8sj/ In regards to the keyfob it is a integrated keyfob on a real Toyota key. I responded to this earlier but for some reason it didn't show. I think because I had initially included a link to show what it looked like. |
3rd and last attempt at a reply without waiting it out. It seems my previous replies were being removed/delayed due to having a picture in them of what I was referring to.
![]() The key I have is a genuine Toyota key with a built-in key fob on it so I'd assume it is an OEM wireless entry. The light is the small yellow/orange bulb nearer to the center of the hood. |
#9 | |
Doesn't it use 7443 bulbs? with dual filament
The parking light and turn signal are in a dual filament bulb, but the parking lights are commoned together. so if the door lock flashes the turn signals, rather than the parking lights, the problem could be a bulb with one of two filaments gone. If that was the case, the turn signal would not work on that side.
Upon looking into it more it seems the light also lights up fine while using my left blinker. The only times the driver-side small orange/yellowish light doesn't light up is with turning the parking lights and headlights on.
Also worth noting pressing unlock/using the blinker with the parking lights or headlights turned on does make it light up during it. Unfortunately the weather here isn't great at the moment so I won't have time to look into it more quite yet but this issue definitely has me puzzled. |
#13 | |
#14 | |
Regardless it doesn't hurt to grab an extra set of bulbs so I'll get some when I get the time this weekend and replace it and see if it solves the issue. |
#15 | |
I went out and bought 7444NA bulbs to replace the current driver-side bulb today as that's what the one already in there was and after replacing the the driver-side one it is now working perfect.
Thanks for the help! I appreciate it. |
| Toyota Hybrid R Shows Its Yaris Roots | MadMax | General Yaris / Vitz Discussion | 0 | 10-10-2013 06:14 PM |
| Toyota Yaris Ready to Rally in 2013 TagRallySport to Run Toyota Yaris in 2013 America | Tagrallysport | Photo-Video-Media Gallery | 7 | 11-15-2012 04:40 PM |
| Toyota recalling 1.53 million cars globally | fnkngrv | Off-topic / Other Cars / Everything else Discussions | 2 | 10-21-2010 02:26 PM |
