The rear twist beams actually work pretty well at soaking up the bumps, and staying planted. Nice video of one here:
https://www.youtube.com/watch?v=5YxV8FzEWAA Honestly, I can't see it being worth the effort, and may even reduce handling abilities if you get the roll-height etc wrong. You have to put some serious thought, and some math into custom suspension packages to get results you want. I would sooner convert the front to a SLA setup to get some camber gain in corners. I have nearly -3° camber up front and still only use the outside 1/3 of the tire (at most!). If you could get the front to use all of the tire in the corners, and still have suspension travel, you would probably be much further ahead. Cheers. |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 09:24 AM |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Rear disc brake conversion installed | Brian | Performance Modifications | 49 | 03-05-2009 12:45 AM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-06-2008 12:37 AM |
